High pitch squeal under acceleration
belt or tensioner would be my guess. How many miles are on the truck?
They make a spray that you can use on the belt to see if that helps, but my guess it won't.
It is either slipping because it is wore out or the tensioner.
Have you reached in there....with the motor off and keys in pocket, and checked the tensioner or visually watched it when the motor is running?
Apply a small amount of dielectric grease to both sides of the belt (engine off) and see if the noise goes away. If it's a high pitched squeal that gets louder and higher with rpm it's most likely an exhaust leak. Possible broken manifold studs or cracked egr pipes. Any soot spots under the hood?
I recently had a similar problem. It would squeal under load, but was really bad when exhaust braking. Turned out to be 2 broken studs on the Exhaust manifold Left side. Ford knows about this problem and makes better studs for the #4, and #8 cylinder. Not sure if this fits your noise or problem, but with a light and a mirror I could see where the exhaust was leaking prior to tearing it apart.
The following users liked this post:
DaviMac424
04-06-2010 08:33 AM
