HELP with 01 7.3 intermediate rough running - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 05-06-2018, 02:19 PM
Red Monkey's Avatar
Red Monkey
Red Monkey is offline
Red Monkey is starting off with a positive reputation.
My 01 F-250 7.3 with 265,000 mi. was running great until about 3 weeks ago. It cranks and idles fine but 'sometimes', usually when hot, runs very rough with no power and blows white/blue rich diesel smelling smoke. when cursing with the cruise control on it 'hiccups' occasionally at highway speeds.
Its shows NO codes when scanned by a certified FORD tech with a Ford computer/scanner.
New fuel filter installed, no help,
New fuel tank strainer installed no help,
Replaced the PCM no help.
Removed the DPTuner no help.
My mechanic says everything is within spec's when its scanned, all 8 cylinders are 'balanced'. I'm thinking it could be an injector hanging open but hate to spend big bucks replacing injectors with KNOWING that's the problem.
We are at a loss as to what could be causing this problem as it's throwing NO codes, even when it's acting up. I'm going to replace the Blue International CPS with a gray Ford CPS today to see if that could possibly be the problem.
If anyone has any ideas please share them.
Old 05-06-2018, 05:23 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is online now
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
I think the DP ate-cho-baby......😉....sounds like injector oring time
Old 05-07-2018, 05:41 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Sounds like a dying fuel pump. A fuel pressure gauge would help here. My understanding is pumps usually just quit rather than work intermittently, but the symptoms and especially the lack of CEL is typical for fuel pump failure. The intermittent failure could indicate a pump wiring issue rather than the pump itself.
Old 05-16-2018, 03:23 PM
Josh Ross
Josh Ross is offline
Josh Ross is starting off with a positive reputation.
Sounds like fuel pump or most likely UVCH wire harness issues. Google 50 cent mod for 7.3. You can test the nine pin connector too with a multimeter. Instruction are on here.
roadrash63
07-29-2011 08:18 PM
Ekkehard
03-14-2010 03:10 AM
BAGRAMVM
1999 to 2016 Super Duty
03-01-2008 12:49 PM
lostmind76f100
Oil & Lubrication
13
03-23-2004 07:34 PM
Polkat
Oil & Lubrication
11-17-2002 03:25 PM
Quick Reply: HELP with 01 7.3 intermediate rough running
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
