Short bed with a 101" 5er - Ford Truck Enthusiasts Forums
Old 05-02-2018, 10:25 PM
KSWilson
KSWilson is offline
KSWilson is starting off with a positive reputation.
Buying a Grand Designs Solitude 344 and an F-350 SRW. Can I get some thoughts on a short bed with a slider vs a long bed, given the 101" wide ? I saw something on a thread that the wider trailer presented some problems with the short bed/slider combo ? Are there any long bed fans who want to talk me out of a short bed anyhow ? I am a rookie, so any help is appreciated.
Thanks !
Old 05-02-2018, 10:34 PM
Fishermanbb
Fishermanbb is offline
Fishermanbb is gaining momentum as a positive member of FTE.
I have a 102” wide 5th wheel with a short bed and a slider (auto slider). No issues at all.
Old 05-03-2018, 09:44 AM
-brent's Avatar
-brent
-brent is offline
-brent is starting off with a positive reputation.
I have 6.8 bed and a 8.5 wide 5th toyhauler with B W slider. Ours is a SRW , however I upgraded tires and rims to get a taller and wider stance from stock. We have no problems.
Old 05-03-2018, 01:06 PM
djousma
djousma is offline
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
My Cardinal is same width, and I run the Demco Hijacker autoslide in my CCSB SRW. Glad I am, not sure it was a requirement. Just not having to think about it is comforting enough. My next truck will be a Long Bed SRW, and I will then ditch the slider in favor of a B&W. My move to LB is mostly to get the much larger fuel tank stock. I could retrofit my 2016 with a Titan tank, but I have a hard time dropping the coin for that, knowing I will trade the truck in in 3 more years.
Old 05-04-2018, 09:13 PM
backtrack2015's Avatar
backtrack2015
backtrack2015 is online now
backtrack2015 is gaining momentum as a positive member of FTE.backtrack2015 is gaining momentum as a positive member of FTE.
That's a good size trailer if loaded to GVW. If you're going crew-cab diesel, I'd be real tempted to go DRW with the simple B&W hitch. The long-bed SRW will have less payload than the short-bed SRW, but you won't need a heavy slider hitch (gain some back). The added fuel capacity and a very simple (two piece) hitch would be nice benefits.
Old 05-04-2018, 10:49 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Paw's 150 Lariat has a great reputation on FTE.Paw's 150 Lariat has a great reputation on FTE.Paw's 150 Lariat has a great reputation on FTE.Paw's 150 Lariat has a great reputation on FTE.Paw's 150 Lariat has a great reputation on FTE.Paw's 150 Lariat has a great reputation on FTE.
Another way to go is to use a Reese Sidewinder pin box. It gives more turning radius on a SWB truck. No need for a slider with this.
Old 05-15-2018, 12:51 PM
kurthb
kurthb is offline
kurthb is starting off with a positive reputation.
What did you go from and to on the tire size?
Old 05-16-2018, 06:33 PM
-brent's Avatar
-brent
-brent is offline
I had 245/ 17 tires on 7.5 wide wheels (stock). I went to 275/ 18 on 9.5 wheels and it seems to make a difference. We have air bags on as well and I never really have a problem.
Old 05-17-2018, 05:14 PM
kurthb
kurthb is offline
Humm...not a bad idea gives more of a footprint....and thus better stability I would assume
Old 05-20-2018, 06:47 AM
RKlass
RKlass is offline
RKlass is starting off with a positive reputation.
I have a SRW short bed with a 101" fifth wheel. I have a B&W patriot slider in mine. First thing I did when I got it all set up was slowly jacknifed in my yard to see how far I could go. How far you can go will greatly depend on the trailer and how the nose is. My old trailer wouldn't come anywhere near this Columbus that I have. The new one is way more rounded in the front and allows me to almost get to 90 degrees. There's no way I could hit the cab while travelling forward unless on some extreme angle so I'm good with that.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
