If buying a used fiver or TT check the slides
I was working the lot last week and took a couple of shots of a common problem (perhaps the most common problem) with slide-outs. When manufacturers put these things together they do not necessarily have longevity in mind and slide-outs have become the problem children of fivers and travel trailers. As you can see in the pictures, the trim at the bottom of the slide-out side leaves press board exposed. The manufacturers seal this very poorly and eventually it wicks moisture, expands, and falls apart. You will not notice this inside the slide-out until a great deal of damage is done, so if shopping used be sure to look for this problem.
These pictures were taken on a Big Horn I was working on and it is also common in Holiday Rambler Presidentials to name only two of a long list. If you have a towable with the edge showing as pictured, seal it with any good wood product sealer and keep it sealed. If you see appreciable damage in a unit you are considering, you may want to walk away or at least get a significant reduction in price. Just a heads-up.
RV_Tech
Fifth Wheel & Gooseneck RV Towing
23
08-29-2016 08:31 PM
