T4/SXE vs. KC38R - Decision has been made...
#331
I'm on my 3rd down pipe....
First down pipe was clocked wrong, second down pipe was clocked right but where the flange for the turbo was welded on was cut to short. Third one is correct (although I do have a slight jog in my flex pipe).
I hope a year later Carson has things figured out with his pipe bender.
#332
Stewart
#333
#334
You guys running these upgraded 7.3's that can hang with the modern diesels can make a man very envious!
Stewart
#335
I’m happy to oblige if you wanna drive a few hours south.....with beer!
#336
Akcooper9 has offered his installation services many times. I thanked him each time and told him I didn't want to turn into cousin Eddie from National Lampoon's Christmas.
I look forward to getting the install done and testing it thoroughly during our trip around the country next spring.
We are headed back to the Washington state area and going to take 60-90 days to go round trip. I suspect this time will be dramatically different than the last trip in 2015 when the truck was 100% stock.
#337
You'll definately notice a difference stock vs mods Sous, although you may have gotten too accustomed to modded in 3 yrs to remember the stock starting point as well. I did the basic FTE mods in sig 1 at a time in between our camp trips and could tell a difference towing with each one. Going T4 will probably be a huge difference for you. I know I'm awaiting your b4 and after torque log comparisons.
Hoping to see you pick up 2 mpg to make it easier to convince a spring purchase to my wife
#345
565Edge, is your frame cracked?
It could be just a squiggle in the frame coating, but thought you might want to take a closer look in case that was a crack initiation site, which appears to follow the same modality (flange edge to relief at hole) as a frame would typically present cracking, and which happens to be located in the area where Ford reinforced the frames in later model years.
Just helping keep you on your toes.
