T4/SXE vs. KC38R - Decision has been made...
#106
I strongly suggest getting at least the housings ceramic coated. I would probably do the up and down pipes as well. It is a little pricey but the side effects are well worth it, lowering of underhood temps and quicker spool. Although the quicker spool doesn't seem to be an issue with this turbo/diesel combo.
#107
#110
I am envisioning black on the CAC tubes, up-pipes, T4 bracket and down-pipe. Then silver on the turbine housing. I will be using the VHT because ceramic coating is not in the budget.
This will be more of a rust preventative, even though I do live in GA. I have seen cast iron parts turn orange in a very short period of time.
#111
Why not wrap the up pipes with header wrap and buy a turbo snail blanket? dont even bothering painting the snail exhaust housing, paint wont last with the heat, and if even the slightest drop of water,fuel or coolant falls on it when hot the paint will come of instantly ask how me how I know...
#112
#113
Look at akcooper's picture. It's a turbo man, not art. bolt the stuff up and run it....Run. The. ****. Out. Of. It
#114
The Brad was nice enough to send me a picture of his turbo as well and it looks a lot like what Akcooper9 posted.
#116
Genuine Borg Warner turbine arrived today. There is a dramatic difference in weight and appearance in the lines between this and the Smeding Diesel turbine. In addition, the color is darker on the BW, not sure if that means anything though.
A few other pieces arrive today from Amazon as well, but they are boring.
#117
This is my new course of action. I may wrap the up-pipes just to try and keep the heat around the firewall down and it is cheap and easy, but no painting (other than the CAC tubes, which the passenger side is painted already) will be taking place.
When I asked Carson about it, he said he’s never had a problem with wrapped pipes, so take that for what it’s worth.
#118
I was actually reading that same article a while ago. Unfortunately, ceramic coating is not in the budget.
I will do more research on the wrap, and make a decision from there. Thanks for your input from Carson had though.
All I know is I am damn glad I made the call to get the BW turbine.
EDIT: I have decided against the wrap as well. Just going to run the parts as they come to me in a box. Reason being is that the wrap must be sealed or painted with the proper spray coat or it could potentially absorb oil and fuel if/when there is a leak. The chances of a catastrophic event occuring are too great of a chance for just a cosmetic change. Ceramic coating is by far the best way to keep parts free from rust and reduce temperatures. VHT is a no go, too many horror stories out there. Wrapping is too great of a risk for very little gain in cosmetic or temperature differences.
#119
#120
