T4/SXE vs. KC38R - Decision has been made...
#91
Your right, I misread the ad title and saw what I wanted instead of what it said. In addition, I completely missed the small section that said "brand: smeding".
It was my fault for not paying attention to detail like I normally do. If the seller does not take the return, I will either relist it on Ebay or sell it to someone through FTE.
I am hopeful my mistake will not be too costly. Either way, I have a genuine Borg Warner .91 housing on the way. I was 100% sure about the purchase this time.
#92
I got lucky and Smeding has accepted the return request. I am thankful that my mistake did not cost me anything other than time. I will take this opportunity to pay more attention to detail, as I have done in the past.
Total cost of parts on order thus far is below.
SXE Super Core $606.11
Turbine Housing $129.74
T4 kit w/CCV port $1,450.00
____________________________________
Total $2185.85
Still a few more little pieces to get on order, hope to get that done today or tomorrow after I finish working on the camper and finishing up some things on the truck.
Total $2185.85
#94
#95
#96
#97
#98
I am just glad I opened the box and saw Smeding on the side of the housing. I would have been pretty pissed with myself if I had waited until the install date and then noticed it. I probably would have shot it and run it over with the truck at that point.
I am going to try to insert a funny comment or something regarding this screw up when I do the install video, we will see though.
#99
#100
Still debating on painting the housing to prevent rust/discoloration. I am currently seeking advice of some of the other BW fellas.
#101
#102
The center section is this?
The mounting plate is this? I don't think you are talking about the pedestal, just want to be clear though.
#104
Well, to be fair, cast iron parts will rust just about anywhere. For example, the IH cast iron water pump that I installed 4 years ago is covered in rust. It still works great and the inside channels are clear, but the exterior sure looks like crap. I should have painted it before installing it, but this was the first repair I had to do to my truck after buying it and frankly I forgot about it.
I am already planning to paint the CAC tubes, so I will probably paint what I can. Probably going to paint the turbo and turbine silver and the CAC and up-pipes black.
#105
I strongly suggest getting at least the housings ceramic coated. I would probably do the up and down pipes as well. It is a little pricey but the side effects are well worth it, lowering of underhood temps and quicker spool. Although the quicker spool doesn't seem to be an issue with this turbo/diesel combo.
