1977 to 1978/79 grille swap
https://www.ford-trucks.com/forums/1...79-face-2.html
Here's a thread from when I did the swap. There's other helpful links in the thread and a couple issues I ran into.
Originally Posted by Kakejelly13
I know the 77 was a switch year, so I heard it wasn't that bad to do.
Uh huh...
Uh huh...
The 1978/79 radiator support with rectangular headlamps is dished inwards behind the buckets, so they will fit in the grille frame properly.
1978/79's also use unique brackets (D8TZ-8232-A Right / D8TZ-8232-B Left) that bolt to the radiator support to retain the headlamp buckets (see upper pic).
Plus, the OP will need complete rectangular headlamp assy's including the headlamp doors. Not just the buckets.
Upper pic: Grille, radiator support, unique brackets (only R/S shown) and misc parts / Lower pic: Rectangular headlamp parts and parking lamps..
You need everything from grill shell out including the top metal plates that hold the buckets to the support. If going the opposite direction you have to lengthen your turn signal wires but not this direction going to older. The 78-79 plastic grill has push pins that hold the plastic grill to the shell that are different than earlier which attached by screws. The headlight trim rings require an extra screw but are same as earlier. I've done a couple and never ran into any issues besides drilling 1 hole on each side. It's been done millions of times if you search and they adjust and function normally.
78-79 round require 2 holes each side to mount the buckets in. Doesn't matter that they didn't have the dimple radiator support.
From this to:
This. Yes you have to get all the other pieces, but if you want round the correct 78-79 buckets must be used but the support is not an issue, headlight connectors need addressing but that's easy got them and spliced them from a donor. Go at it boy!
From this to:
And there are TWO different round headlamp supports, because the support used with the SUPER COOLING has a larger opening radius.
1973/79's with roundheadlamps use a different radiator support than 1978/79's with rectangular headlamps. 1978/79's have the dimple for the buckets, 1973/77's do not.
And there are Two different round headlamp supports, because the support used with the SUPER COOLING has a larger opening radius.
And was the super cooling available for the 78-79 square years?
ND, wouldn't there have been 3 different supports? The six cylinder definitely has a smaller opening than the V8's.
1973/79 = TWO different radiator supports with round headlamps. Another for 1978/79's with rectangular headlamps.
Super Cooling radiator measures approx 26 1/4" high x 24 11/16" wide.
See 16138 in pic: Notice D8TZ-16138-A has "locating depressions" for headlamp buckets.
Looks like I guessed wrong above...
It also seems to state that there are no 25.5" opening rad supports for rectangular headlights.
Only Customs have round headlamps in 1979 and most were "stripper" aka price leader Flaresides sold to the US Gov't, and to fleets (petroleum/construction/telephone companies).
