One up off road traction bar 3” lift block install
recieved it today.
its going on my 2010 f-450 Drw with the Dana 110 axle.
goal for today is to try to get the lift blocks and bottom traction bar plate installed.
alm old plates and ubolts Ned to come off and all new need to go on.
left to right on photo
traction bar plate
ubolts
3” lift blocks
bed side traction bar mount
hardware in white boxes
big box has the bars
now to lift the back and try to break all of he bolts loose. Sprayed penetrant on them last night
may the force be with me
Good news/ bad news
the bad news....top plate is bolted to the shin stack
the good news....I didn’t need to remember ve the top plate just lift the leaf springs, insert 3” spacer, then install bottom plate for traction bar eyelets
left side if done
right side after lunch
bars will be next weekend
got both spacers and traction bar eyelet plates installed
i like these lift blocks becuse they have flanges for the bump stops
this was a nine hour affair just to get this far.
had most of the tools except for a 1 1/16 socket for the old u bolt nuts.
next Saturday will be the drilling for the side chasis mounts for the front bar eyelets
also going to check my axle alignment
azarchery
09-13-2018 08:59 AM
speakerfritz
1999 to 2016 Super Duty
04-28-2018 05:43 PM
