Any Practical Way To Measure Out 13 Quarts Of Oil? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 04-27-2018, 09:11 AM
MPawelek's Avatar
MPawelek
MPawelek is offline
MPawelek is starting off with a positive reputation.
I have noticed that 5 gallon containers of engine oil are better priced than smaller units. Anyone have a practical way to measure out and pour 13 quarts without making a mess? Thanks....
Old 04-27-2018, 09:22 AM
razehm
razehm is offline
razehm is starting off with a positive reputation.
5 gallons or 5 quarts? Pour two of the 5 quart containers in and then do the back and forth with the third of pouring and checking. Unless you really found a 5 gallon bucket of motor oil.
Old 04-27-2018, 11:10 AM
jav_eee
jav_eee is online now
jav_eee is gaining momentum as a positive member of FTE.jav_eee is gaining momentum as a positive member of FTE.
A 98 cent painters cup could measure out a quart for you.
Old 04-27-2018, 11:17 AM
djousma
djousma is offline
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
Oddly, I've never seen diesel oil in 5Q containers, only gas engine oil. Now, I do buy all my oil in gallons, and every one that I've had, from multiple brands, all have Liter/Quart markings down the side of the container. I start out with 4 gallons, and for the 3 subsequent oil changes, I only need to buy 3 gallons. That's how I measure out the last Q I need for oil changes, and I usually pour the majority of this quart into the new,empty oil filter.
Old 04-27-2018, 05:54 PM
G-Dad
G-Dad is offline
G-Dad is starting off with a positive reputation.
Motorcraft diesel oil is in 5 qt containers at Walmart. I get two of those and three one quart containers.
Old 04-28-2018, 11:00 AM
mebe2k's Avatar
mebe2k
mebe2k is offline
mebe2k is gaining momentum as a positive member of FTE.
I just use a 1 gal. DELO bottle and fill it 3 times +1qt...I got a bunch of the DELO 5 gal pails from tractor supply..they had a bunch of CJ4 so I decided to start hoarding CJ4...
Old 04-29-2018, 06:40 AM
Just Strokin
Just Strokin is online now
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
dump two of the 5 gallon jugs into the engine. Then using one of the two empty containers, pour 3 quarts into one of the empty containers. Or, you can find 3 each one quart oil bottles and fill them. Or find a one gallon oil container and pour 3 quarts into it.
Go to one of the local auto shops that change oil and I bet they will give you all the empty one quart or one gallon or 5 quart containers you want.
I have a similar problem with parents Escape turbo as it uses 4.7 quarts of oil. I got a quart bottle and measure out .3 of a quart into it from the 5 quart bottle. That leaves 4.3 quarts in the 5 quart container.
Old 04-29-2018, 09:09 AM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is online now
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Guys, I think the OP is talking about these. I was always curious how you'd measure if using them too...
Old 04-29-2018, 09:12 AM
Karl4Cat's Avatar
Karl4Cat
Larry, start with 40 quarts of oil?
Old 04-29-2018, 10:04 AM
cangim's Avatar
cangim
cangim is offline
cangim has a good reputation on FTE.cangim has a good reputation on FTE.cangim has a good reputation on FTE.
On farm we used 55gal drums and had a hand crank to fill smaller container when doing tractors and such. If they made a hand crank for a 5gal bucket that'd be slick, cut into your cost for a bit thought. Points for cool factor...
Old 04-29-2018, 10:18 AM
razehm
razehm is offline
For the guys who are doing their own oil changes, what are you using to capture the used oil when you change it? If it holds 13 quarts, if you bought a brand new one could you mark 13 quarts to measure it out and never use it for the old oil? Just a thought, I still have the dealership do mine to keep the warranty forever.
Old 04-29-2018, 10:25 AM
cangim's Avatar
cangim
cangim is offline
I use a 5 gal bucket, slap lid on it and then over to local autoparts for recycle
Old 04-29-2018, 10:55 AM
Karl4Cat's Avatar
Karl4Cat
Use an EZ Drain oil valve and a short section of tubing. Then drain right back into empty gallon jugs. Not a drip on the floor with this method.
Old 04-29-2018, 11:14 AM
Just Strokin
ooooooops......was before first cup of coffee.........lol
He needs to go get some used 4 or 5 quart containers from oil change place and fill them from the 5 gal pail huh?
Old 04-30-2018, 03:33 AM
mebe2k's Avatar
mebe2k
mebe2k is offline
Harbor Freight has a hand pump for the 5 gal buckets for $14.99...I have 2 of them..one for my DELO buckets, and one for my hydraulic fluid buckets..
Quick Reply: Any Practical Way To Measure Out 13 Quarts Of Oil?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
