2002 f250 replace the cig. lighter and power point with USB
I know there are several threads about this already, but I'm looking for info. on a direct replacement usb port for both areas. I would prefer one that doesn't have a volt LED readout or a colored light. (I guess a white light would be ok) I don't want to modify the plastic dash if at all possible.
I recently put one similar to this (I got one with a voltmeter display), same dimensions to replace the power point. It fit the hole perfectly, but I did have to change the terminal ends on the truck wiring.
