Opinions on tow capacity
Hi Guys, I have a 14 f250 fx4 4 door swb, do you think I would be within range on the following tow capacity?
I am looking for my first 5th wheel, it has a gooseneck adapter and the specs are as follows:
dry weight 11230
cargo weight 2770
hitch weight 2340
length 38'6"
I am just looking for suggestions, thanks in advance
dry weight 11230
cargo weight 2770
hitch weight 2340
length 38'6"
Is your F250 a Diesel, you didn't say.
Will it do it? Yes
Will you need air bags? most likely
Will you be over your 10000# gross of the truck? Yep even if you have a gas burner.
A 2340 pin weight is about 21% of the 11230 dry weight, which is about where we would expect it to be. If we assume that the 21% would also apply to the 2770 cargo capacity, then you are looking at about another 580# of pin weight putting you at just over 2900# pin weight. Add driver, passengers, and assorted stuff in the bed and you are easily adding another 600 to 800 pounds or more to the load. Even a Gas F250 doesn't have the capacity to handle 3500# or more and stay within its 10000 limit. But as stated earlier, it will do it, but you might not be happy with the result.
I had a 2013 F250 Lariat with 3.55 gear and a 2109# cargo capacity based on the door sticker. With me, my wife, our two Great Danes, and fire wood in the bed of the truck, we were down to about 1000# load capacity available. I bought the truck to two a 35 foot travel trailer and it did great! But we decided to upgrade to a 5th wheel and bought a Sierra 371 REMB. Sales said it would pull it no problem. I didn't do my homework, and went ahead bought the unit and then tried towing with my F250. The Sierra 371 REMB has a 15500 gross and about a 12800 dry weight. At the time pin weights were advertised as 1835#, so I figured heck I had a 2109# load capacity, didn't consider everything else I was loading in the truck or that loading the trailer would drive the pin weight up as much as it did. I needed air bags pumped up to 50# to level the truck up and handle the 2800# pin weight of the camper when we were loaded for camping with a 14000# gross, but it got the job done. Longest trip was about 500 miles out and 500 miles back, had no issues other than it felt greasy when big side winds hit us causing a lot of tail wag and she like to porpoise, but it did the job for a couple of years. Now I tow with an F350 Dually and don't worry about exceeding the trucks 14000# gross.
Hope this helps a bit.
Brent
Not sure if that helped you or not,
Will it do it? Yes
Brent
d50h........if you have the 6.7 Diesel, your payload capacity is going to most likely be around 2100 lbs +/- either direction. You will be way overloaded on your payload numbers (Cargo Carrying Capacity...CCC). Check the sticker, which is white/yellow (driver side door post.) and find the actual number for your truck. There are folks that will tell you that you will be fine as long as you don't exceed the tire capacity and or the rear axle capacity.....I'm not one of them! Ford tells you very clearly in the owner's manual to NEVER exceed ANY of the capacities.....GVWR, front and rear axle rating, towing capacity, combined towing capacity. They don't say that it's OK to pick and/or choose which one or more to exceed.....They say to NEVER exceed ANY of the capacities. And let's face it, if you start out with the pin weight already over payload capacity, it's only going to get worse from there.....5ver hitch, passenger(s), tools, firewood, extra fuel.....anything and EVERYTHING that goes in or on your truck has to be calculated against the 2100 lbs of payload ( or whatever number yours actually has), based on that door post sticker. Air bags might help your overloaded truck to ride more level, but they do absolutely nothing to increase the payload capacity.
And one final thought here, since the title of your thread mentions "opinions". Towing capacities are NOT based on someone's "opinion", they are hard numbers that are determined by the manufacturer of the vehicle. People constantly try to "bend", "twist", and manipulate those numbers for their own use and then justify it by saying that they aren't over this capacity or that capacity. To me, if it's clearly stated that you should never exceed ANY of the capacities, then it's case closed.
I debated the F250/350 and listened to feedback on FTE, The 2017/18 F250/350 have exact same frame/brakes. F350 has more spring's..The F250 rear axle I believe was the standard 2016 F350 rear axle. You will be over sticker ratings, but stopping etc will be fine, make sure you have highest load rated tires..
For me, I don't want much longer than I have (32 feet) mainly for maneuverability reasons.
My 2002 diesel 3/4 ton with 8 foot bed and extended cab is rated for 3400 lbs payload (and verified by weighing the truck empty). Did Ford make the new trucks less capable? is there any reason for buying an F250? Kinda hard to answer that and comply 100% with the owners' manual.
dry weight 11230
cargo weight 2770
hitch weight 2340
length 38'6"
dry weight 11230
cargo weight 2770
hitch weight 2340
length 38'6"
BTW - Take the tow police on this forum with a grain of salt. Most of them would have us towing with a semi rig
