302 EFI Upper Manifold Waterlines
Can the waterlines that run from the heater water supply tubes to the upper manifold on a 1998 302 EFI be eliminated? Why are these lines connected to the manifold? Are they there to cool the manifold or heat it up in cold weather? I am not going to use this engine in a vehicle where heat is required so I want to eliminate the heater tubes. If the water is required in the manifold for normal operations, I will have to fit up some kind of adapter.
dnewman50
06-13-2011 12:15 PM
guin7714
01-26-2009 06:49 PM
cdherman
10-31-2003 07:26 AM
