!952 Ford F1 Center Grille Tooth
Old 04-22-2018, 01:29 PM
m9gray1
m9gray1 is offline
m9gray1 is starting off with a positive reputation.
I am looking for the center grille tooth from a 1951 or 1952 Ford truck. Would consider buying a set if needed, but really just need the center tooth. The left and right in my set are in good shape. The center tooth not so much.
Any help is appreciated.
Old 04-22-2018, 02:49 PM
Muppy1840's Avatar
Muppy1840
Muppy1840 is offline
Muppy1840 has a very good reputation on FTE.Muppy1840 has a very good reputation on FTE.Muppy1840 has a very good reputation on FTE.Muppy1840 has a very good reputation on FTE.
I might have one. Let me look through my extra parts. , Doug.
Old 04-22-2018, 06:27 PM
m9gray1
m9gray1 is offline
Doug, That would be great. Thank you for looking. Will be waiting anxiously for an update. for sure!
Old 04-22-2018, 07:06 PM
firstrider's Avatar
firstrider
firstrider is offline
firstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to beholdfirstrider is a splendid one to behold
If one does not surface I will be able to acquire one mid June .Let me know .
Old 04-22-2018, 10:50 PM
Muppy1840's Avatar
Muppy1840
This is what I have. Not rusted out but has a dent. Not sure if this will work for you.
Old 04-23-2018, 08:56 AM
tinman52
tinman52 is offline
Welder User
tinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputation
I may have one also if Muppy's doesn't work
Old 05-14-2018, 01:15 PM
m9gray1
m9gray1 is offline
Hi Doug,
Sorry for the delay in getting back to you. That one is in better shape than mine. I am interested. I will try and PM you to connect. Thanks.
Max
Old 05-14-2018, 01:17 PM
m9gray1
m9gray1 is offline
Hi Tinman52
Thanks for the reply. If you wouldn't mind, can you share a pic of the tooth you have. I think I can likely knock out the dent on Muppy's but would be glad not to have to do that. Appreciate the time and response.
Max
christurney77
04-17-2015 07:18 PM
John Morton
11-02-2008 12:00 AM
John Morton
09-01-2007 12:07 PM
M6EV139445
02-14-2007 11:19 AM
John Morton
09-29-2006 10:58 AM
Quick Reply: !952 Ford F1 Center Grille Tooth
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
