Engine block wash after hone, instant rust
Building a 5.4 Modular.
So I feel like an idiot but what was I suppose to do. I bought a new 5.4 block from Ford. Did a light touch hone on the cylinders to get a good cross hatch. Then washed the block with brake clean first then water to get the hone debris out, can be too clean right? Well as I blow dried the block, blowing out all the water etc, all the surfaces turned rusty. A good wipe down and some WD40 made it look better. My concern is the oil galleys on the inside, pushing the rust powder into the bearings on first fire up. Is this something I should be concerned about or is it going to dissolve and pass thru and get caught by the filter. I plan on running some solvent thru the main galley to get as much out as possible, blowing it out and then a light coat of WD40 to preserve.
Should I worry and what would you do?
You should get a bore gage and mics to check piston clearance. I would not just trust where the factory left it. What kind of rings you use will determine the grit of finish stone you use. You should also be using a fixed hone, nothing spring loaded. Like already said, wipe the cylinders with a clean paper towel till they are clean.
timmygyu
08-03-2014 09:17 PM
jkidd_39
09-05-2010 09:29 AM
Dyerstown
06-14-2003 01:40 PM
