Scrubbing/squeaking sound under truck while driving
Rear drive shaft is easy to remove. I took mine in for a rebuild.
This is where I was going to post a photo of my Superduty driveshaft in the passenger side of the Prius, but photos aren't working today.
Uh... a 2-ton floor jack is too small. My truck weighs 8000 with a little light cargo and a topper. I have a 3-ton floor jack.
The front drive shaft should be completely free. Mine doesn't turn unless a hub is locked, stuck, or the transfer case is in 4WD. It sounds like something is turning your front drive shaft, or your transfer case needs service. Transfer cases are very inexpensive compared to a lot of the other hardware on the truck.
I put the truck on 4 jack stands and put it in 4wd and put a stethoscope on the front of the transfer case where the drive shaft attaches and can hear the squeaking while running in 4 wd. I put it in 2wd while still on the stands and only hear it occasionally. Put the truck on the ground and the noise is there whether it’s in 2wd or 4wd. So I’m thinking it’s possibly the front driveshafts u-joints or possibly something in the transfer case... Any suggestions?
Figured it was a bearing somewhere! Glad ya found the cause. Now, as far as part numbers go...
U-joints, Greasable: 3x Spicer 5-178X
CV Ball: 1x Moog/Precision 617
-or-
U-Joints, Non-Greasable: 3x Spicer 5-1350X
Personally I always go greasable, but seeing as the double cardan is tight, I understand about opting for the non-greasables. To my knowledge Spicer unfortunately doesn't make a CV ball, otherwise I'd have given you their part number for that as well.
Good luck on he project! Hope it won't be too hard on ya.
-or-
-or-
-or-
