Number Dummy Come On In - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 04-21-2018, 07:23 AM
75BigBlock's Avatar
75BigBlock
75BigBlock is offline
75BigBlock is starting off with a positive reputation.
I completely forgot. I'm in need of some fasteners for my Bronco. I don't know the nomenclature. There's a window track that goes into the removable top for the rear glass. It's held into place with some fasteners and then the weatherstripping goes over it all. I have some pics that may or may not help. They are T shaped. Thanks.
Old 04-21-2018, 11:57 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
I don't see any clips and there's no attaching parts listed for 422A36 or 42372.
Old 04-21-2018, 08:27 PM
75BigBlock's Avatar
75BigBlock
They would be used to hold 42372 onto 42034. I took one off the donor vehicle and it was pretty rusted up on the threads and obviously didn't look like a typical nut/bolt setup. It's basically a nut and bolt, but instead of a bolt head it has that flat part that is in the second pic that's low profile as to not get in the way of the weatherstripping.
I'll go back at some point and pull the rest and maybe I can make them usable OR maybe the other, later year Broncos use the same fasteners. Thanks for checking it for me!
Old 04-22-2018, 09:54 PM
McLeod's Avatar
McLeod
McLeod is offline
McLeod has a good reputation on FTE.McLeod has a good reputation on FTE.
Interesting.
I just replaced that rear glass run on my '95 a month or two ago.
On mine, the glass run installed directly into the top without an additional channel piece in there.
The new weather strip had a plastic pin on each side to lock it into the channel in the top and the rest was a press fit.
I bought mine from JBG and it was a DC piece and is high quality.
Maybe the clip /pin on yours separated from the weather strip and remained in the channel?
Here is an exploded diagram of the 78/79 from LMC that doesn't show what you are looking for either.
Truck Parts and Truck Accessories
Old 04-22-2018, 10:08 PM
75BigBlock's Avatar
75BigBlock
Originally Posted by McLeod View Post
Interesting.
Yes, its odd. I've checked online at various places and the only thing I saw that was close was a clip that holds the outside trim on the 70's-80's trucks. I'll take a pic of one of the fasteners at some point and post it whenever I remember to. I know these fasteners AREN'T part of the weatherstripping, because I pulled the weatherstripping out of this channel on this parts Bronco to use on mine since it was still in very very good condition and was probably replaced relatively recently before it met its fate in the yard. If you remove the covers on the inside of the top that are up above the window they'll reveal holes that you can reach into and remove the nuts from these fasteners. If you remove all the fasteners, the window track comes all the way out. I can't remember how many of mine are missing, I'll have to go look, but I'm assuming its all but the lower two because my track will sway back and forth within the top pivoting from the bottom.
Here's the clip I was referring to that was the closet thing, looks wise, to what is in my top. They have what looks like a rubber piece in the middle of this clip, but if you took that out this would be pretty close. I'm not sure on the size of the two clips, though.
https://shop.broncograveyard.com/198...ctinfo/35199B/
Old 05-10-2018, 11:18 AM
black & blue 78/9
black & blue 78/9 is offline
black & blue 78/9 is starting off with a positive reputation.
Clip
I have had 4 78 & 79 broncos and my current 79, and all 5 of them had/have that clip that hold the channel.
Old 05-22-2018, 01:23 PM
rusty7983's Avatar
rusty7983
rusty7983 is offline
rusty7983 is starting off with a positive reputation.
I need number dummy help too, my 92 bronco needs a engine control computer. On all the parts store websites, they all say to check factory number and mine is remanufactured and the number cannot be read. 92 bronco 5.8 automatic federal emissions. Thanks
Old 05-22-2018, 01:48 PM
NumberDummy
There are FOUR different "Powertrain Control Modules" (aka processor, aka computer), I need the Calibration Code.
Old 05-30-2018, 09:29 AM
rusty7983's Avatar
rusty7983
I will look at it again. I had it out to check it a while back, and couldn't read the numbers, like they are faded or wiped away. Thanks
Old 05-31-2018, 05:33 PM
rusty7983's Avatar
rusty7983
Can it be looked up by vin?tthanks
BlackLabel78
03-03-2010 04:31 PM
turnrjr
02-08-2009 10:11 AM
lisagoud
11-29-2008 05:34 PM
J1MMY
10-14-2008 12:38 PM
dbossman
08-26-2008 05:05 AM
Quick Reply: Number Dummy Come On In
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
