1978 - 1996 Big Bronco
Temp Gauge Swich
Old 04-27-2018, 02:54 PM
tassmannn's Avatar
tassmannn
tassmannn is offline
Question Temp Gauge Swich
OK. I was driving my 1996 Ford Bronco 302 the other day and my temp started to read towards the hot side, and then came down, back up, then down. Thought my thermostat was sticking or I was over heating, but the temp to the computer was well in range from the other switch. On the one that goes to the temp gauge, I have a tool that fools the gauge that it is a sending unit, and the gauge stayed in the normal range as it should...gauge good! switch right? replaced with three different after market sending units, and same problem, and all of them had around 350 ohms resistance, and Ford tech manual said this needs to be 74ohms, but the motorcraft sender was out of stock at Ford. Got it yesterday, but before I put it in it read 256 ohms, but put it in anyway. and did the same thing. Engine is not overheating and computer reads normal. What in the world am I missing ?
Old 05-02-2018, 12:50 PM
tassmannn's Avatar
tassmannn
Wow...not one response. I thought for sure a Ford tech would have an answer on this one LOL
Old 05-12-2018, 12:41 AM
black & blue 78/9's Avatar
black & blue 78/9
black & blue 78/9 is offline
Bump bump bump
Old 05-12-2018, 10:29 PM
McLeod's Avatar
McLeod
McLeod is offline
Maybe you have air in your coolant system.
Old 05-17-2018, 02:22 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,156 Likes on 914 Posts
I have been watching this thread to see if someone smarter than I could answer your questions. It looks like Ford used the same temperature sender for many years. I also looked through various years' EVTM manuals to see that same value listed (74 to 9.7 ohms). From my research I believe those values are for normal engine operating temperatures, not room temperature to engine overheating.
It takes some reading in between the lines, but this thread has some real world values for a typical Ford temperature sending unit and where the temperature gauge was pointing: Ford Mustang Forums : Corral.net Mustang Forum - View Single Post - Randy, I need your help please, I think my local Ford Parts Dept is clueless.
Based on those results I would say the sender(s) are okay.
I know you stated you used a tool to simulate the sender, but what were the resistance values used throughout the gauge range?
Old 05-17-2018, 09:24 PM
tassmannn's Avatar
tassmannn
Very good comments. Ford doesn't have an answer for this as these newer indicators seem to be generic for a variety of applications. They show exactly what you say, but when we test these senders, they have a higher ohm rating on them cold( around 174). What we are going to do is put a 100 ohm resister in-line...stay tuned
Old 05-19-2018, 06:46 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Is the resistance in the wire to the sender changing ?
Old 05-28-2018, 10:42 PM
tassmannn's Avatar
tassmannn
no, we were told they were trying to standardize sending units for multiple applications. I am going to put a resister in-line but am gonna try to find a NOS sender or pull one from engine at pick and pull to test theory
Old 05-30-2018, 08:16 AM
dmash's Avatar
dmash
dmash is offline
I had this problem years ago with a ford car. The temp gauge would vary with the amount of electrical load, i.e. lights, A/C fan speed. I finally found the body ground was not good and there was a ground potential difference between the block and chassis. Once I cleaned the connections everything was OK.
Old 05-30-2018, 08:24 AM
tassmannn's Avatar
tassmannn
Thumbs up
Hmmmm That's interesting and makes sense...although the guage was still reading 174 ohms when it's suppose to be 74. I'm gonna still look at grounds.Thanks
Old 05-30-2018, 08:23 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Are you going to try adding the parallel resistor ?
Old 05-31-2018, 08:04 AM
tassmannn's Avatar
tassmannn
Yes...seems like the best fix. I didn't find a bad ground
dthut
04-08-2017 11:35 PM
hharris8
22
08-05-2016 04:00 PM
Oversize
02-23-2009 10:30 AM
Narwhal
05-21-2007 11:23 AM
matt77F2504x4
05-27-2004 12:13 PM
Quick Reply: Temp Gauge Swich
