1978 - 1996 Big Bronco
1995 bronco shifting hard
Old 05-31-2018, 02:23 PM
Matthew Edwards's Avatar
Matthew Edwards
Matthew Edwards is offline
Shifting hard speedometer doesn't want to work and odometer isn't worming don't think the trannys going out but idk what u guys think?
Old 05-31-2018, 04:00 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
start by replacing the speed sensor located on top of the rear differential. If the issue continues your 4wabs module located under the washer fluid resiviour is probably suspect as all this travels thru it. You can test this by placing jumper wires into several pins.
Old 05-31-2018, 07:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,573 Likes on 1,051 Posts
If the computer isn't getting a vehicle speed signal the trans will shift hard and erratically. Fix the speed issue and the trans will almost certainly be fine..
Waynebullock
06-18-2017 09:08 PM
RoyGene
05-05-2015 09:46 PM
hillbilly469
12-06-2013 08:07 PM
Tkamenca
11-27-2012 12:50 PM
bigroy
05-15-2005 10:10 AM
Quick Reply: 1995 bronco shifting hard
