6 x 7.25 x 17" Split Rim Replacement/ Modification Choices
Old 05-09-2018, 09:36 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
So for “next guy” reasons may I see if I have it right? Using the below cart, a stock 5 1/2” wide widow maker has 9/16” of positive offset according to Budd, and a backspace calculation of 2 3/4” (rim C/L), + 1/2” rear rim lip, + 9/16” (positive offset) = 3 13/16” backspace.
I’m editing out what I said first because I think I’m confused. You say you added 1/2” of backspace to 3 13/16” which yields a 4 5/16” backspace. That puts the offset figure to 5/16”. Is that right? Stu
Old 05-09-2018, 09:42 AM
bc4x4f250's Avatar
bc4x4f250
bc4x4f250 is offline
bc4x4f250 is starting off with a positive reputation.
Stu,
To confirm the correct number, we will have to pull a wheel... should have actually measured before.
We will reply as soon as we can get a wheel off [in the next few days, hopefully].
Wm.
Old 05-09-2018, 05:29 PM
bc4x4f250's Avatar
bc4x4f250
Per Tim, @ Collins, he was sure the Backspacing was originally 3-1/2", and now it would be 4"...
truckdog62563, we may splitting hairs, but it is - pretty much - as you have worked out in your previous post.
Old 05-09-2018, 05:55 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Backspacing vs offset.
Old 05-09-2018, 05:57 PM
truckdog62563
Splitting fractions doesn’t matter. Plus, the use of 1/2” for the rear rim lip is a commonly used generic figure that may or may not be exactly right in all cases. Thanks. Stu
Old 05-09-2018, 11:08 PM
bc4x4f250's Avatar
bc4x4f250
Stu,
Let me apologize, for not following what you wrote, rather I chose to opine on that which I thought I read.
The only numbers that I had to work with were the following;
3.5" Backspace [original*]
4.0" Backspace [replacement*]
* = per Shop
5.5" Rim Width [original]
7.0" Rim Width [replacement]
So... if the original rim had an offset of 0.75" [+/-], then the replacement rim should have an offset of 0.50" [+/-], as comparing a 2.75" center-line vs. 3.5" center-line.
I hope this actually makes better sense...
Wm.
twinzilla
WTB - Parts & other
02-23-2014 02:12 AM
khakushia
12-04-2011 10:55 AM
2000gpr
1997-2006 Expedition & Navigator
01-20-2008 05:28 PM
kcidmil
1999 to 2016 Super Duty
17
11-01-2007 09:04 PM
Quick Reply: 6 x 7.25 x 17" Split Rim Replacement/ Modification Choices
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
