what is correct size for turbo wheel thread??
problem is it the turbo shaft is what I need to know the size of. I got my heatgun out and got that sucker HOT and tried to spin on... nope.. I can feel the thread start to turn when i push on the shaft it sorta binds up a bit and hold the shaft still.. The wheel will start to turn on shaft threads and then bind.. Same thing when i try to run the tap through old wheel it WILL NOT GO. the 1/4- 28 is NOT the correct size of the shaft for some reason. I don't want to cross thread the wheel so for now going to bag this deal. bummed
Try the tap in the old wheel if it turns in it’s the same thread.
Sounds to me like the tap drill hole in the new wheel may be a little small if that is the case it will be a tight and if the shaft is a little to the top of the tolerance that would make it even tighter.
As a machinist I run into this at times if you have access to a local machine shop have them check the hole in the wheel with a set of calipers or gage pins to see if it’s tight. If it is they can ream it a tiny bit to give it clearance.
shawn
shawn
the tap will not thread or screw into the old wheel but will in the new one which tells me they are different. The hole in wheel is ok size as the shaft will slide through the body to bottom of threads but the shaft will not thread into the wheel. going to measure the threads tomorrow in the light. or try to.
shawn
shawn
I honestly think you are in over your head on this one. Rather than make this harder than it needs to be why not just pull the turbo and install it correctly? All the wheels I have ever installed either say on the website or on the box to not install on the truck or with an impact. I bet between KC, Riffraff, and Dieselsite there are probably 10's of thousands of these wheels out there so unfortunately it sounds like it is an installer experience issue.
I appreciate your candor but I was not wanting to pull turbo, which is a PIA job as you may well know just to replace a turbo wheel. I was able to remove the OEM wheel without taking turbo off, and installing the other wheel, i was taking off now, without removing turbo so I think i have a handle on doing this. I did remove the turbo to replace pedestal o-ring, new 360 bearing, redo fuel lines, adjust torque on rocker arms and injector hold down clips.
but thanks for your concern.
Stop and pull the turbo
I will guarantee you the you have wasted more time messing with this and typing replies than it would take to pull the turbo. R&R of a turbo is a 2-3 hour Job. I have swapped many wheels out and it is much easier with the turbo off. All wheels as already mentioned are snug going on. You will almost always have to hold the turbine wheel to install a new compressor wheel.
2000Ford2000
06-06-2012 07:59 PM
Milwaukee1979F150
02-17-2012 09:25 PM
