Water Separator Fuel Separator Cartridge - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 04-17-2018, 03:11 PM
Redrockerstl55's Avatar
Redrockerstl55
Redrockerstl55 is offline
Redrockerstl55 is gaining momentum as a positive member of FTE.Redrockerstl55 is gaining momentum as a positive member of FTE.
Hey Guys,
So on Saturday I went to drain my water separator and that bright yellow plug was barely held in place on the cartridge element. Then when I went screw it back on it would not latch.
Yes...it was broken. Thankfully someone here on the FTE forum recommended I buy a back up. I did. I needed it. I was saved from having my truck paralyzed on my driveway until Monday morning (my guess is Autozone doesn't carry that part).
I decided to make a quick video of this process to help anyone who may find themselves in a similar situation. I also explain how to drain the cartridge.
Then I show how to refill the cartridge with diesel after you drain it.
Hope this helps someone out there.
Thanks.
Old 04-17-2018, 03:30 PM
SoylentSaxgod
SoylentSaxgod is offline
SoylentSaxgod is starting off with a positive reputation.
Nice video. Thanks!
Old 04-17-2018, 03:59 PM
Redrockerstl55
Thank you. Much appreciated.
Old 04-17-2018, 04:07 PM
Desert Dave's Avatar
Desert Dave
Desert Dave is offline
Desert Dave is starting off with a positive reputation.
Good advice, and nice video!
D2
Old 04-17-2018, 04:16 PM
davew593
davew593 is offline
davew593 is starting off with a positive reputation.
I just drained mine for the first time today (1000 miles) Thanks so much for the video. I will be buying a new one immediately!!!
Old 04-17-2018, 04:35 PM
wicked 2018
wicked 2018 is online now
wicked 2018 is starting off with a positive reputation.
part number: HC3Z-9J305-A
Old 04-17-2018, 08:34 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud of
Any suggestions on where to buy a couple plugs online where I don't pay more to ship them than the product itself costs?
Old 04-18-2018, 02:53 AM
jrwinger's Avatar
jrwinger
jrwinger is offline
jrwinger is starting off with a positive reputation.
great video! I just ordered a few extra plugs for my rig. Thanks for explaining the process
Old 04-18-2018, 03:07 AM
TheLex's Avatar
TheLex
TheLex is offline
TheLex is gaining momentum as a positive member of FTE.TheLex is gaining momentum as a positive member of FTE.
Thank you for posting that. I'm definitely going to pick up a couple of those before embarking on our summer trip!
Old 04-18-2018, 04:52 AM
RONMCHUGH's Avatar
RONMCHUGH
RONMCHUGH is offline
RONMCHUGH is starting off with a positive reputation.
Just ordered a few myself as I live in a rural area and like doing my own maintenance . Thanks for posting the vid !!!
Old 04-18-2018, 09:00 AM
Mainedieselman
Mainedieselman is offline
Mainedieselman is starting off with a positive reputation.
Excellent advice and video. I do almost all my maintenance and thoroughly appreciate your efforts. Will purchase two plugs ASAP.
Old 04-18-2018, 09:30 AM
Spence144db's Avatar
Spence144db
Spence144db is offline
Spence144db is starting off with a positive reputation.
Thank you
Thanks for the heads up!! I just picked up 2 myself and will leave them in the tool box in the back. Its guys like you that help to make owning these trucks a better experience through sites like this.
Old 04-18-2018, 09:54 AM
Seastacker
Seastacker is offline
Seastacker is starting off with a positive reputation.
Great Vid! I will be getting a spare ASAP now that I see how easy they break. Hopefully there is a design tweak/ improvement at some point or someone solves the issue in the aftermarket.
Old 04-18-2018, 11:35 AM
wb6anp
wb6anp is offline
wb6anp has a great reputation on FTE.wb6anp has a great reputation on FTE.wb6anp has a great reputation on FTE.wb6anp has a great reputation on FTE.wb6anp has a great reputation on FTE.
any one have a cnc machine? Maybe try and make one out of aluminum, might be a could way to make extra money.
Old 04-18-2018, 11:44 AM
roadpilot
roadpilot is offline
roadpilot is gaining momentum as a positive member of FTE.roadpilot is gaining momentum as a positive member of FTE.
Many will appreciate your video, but I have a question. Can you clarify, with specific reasoning, why you're stating that you should not pour the fuel back into the vehicle?
Of COURSE if there is water or something else otherwise contaminating the sample, you wouldn't want to reintroduce it to the fuel system.
But assuming NO water was found to be present (very obvious by looking at it) and assuming your (clear glass) container was not otherwise contaminated and you didn't allow anything other than diesel to go into the container, there's nothing but 100% ULSD in the jar. It's no different that what came from the pump to begin with.
I'm just curious if your advice is just a precautionary "just in case" scenario, or if there is specific reasoning for it.
Thanks.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
