How far would you go to get your truck in the garage
Here's what I had to do to my garage to get my new '17 F-250 in it mainly because my driveway slopes down to the garage slightly. I was determined to get it to fit. The '17 is quite a bit taller/longer than my '12 which fit easily.
1. Adjust the garage door to its maximum height.
2. Cutout trim/wiper piece so cab lights would fit under the header.
3. Remove drywall and shave a wall stud so bumper would fit
4. Made a 4X4 "frame" to stop the truck exactly where I want. Then I let it roll off the 4X4's and set the parking brake.
5. Installed a 21'' antenna on the truck.
I realize this is absolute insanity but that thing was going in there whether it liked it or not!
Gotta do what you gotta do.
I have a 3 car attached garage, but I built a 24' x 36' three car detached garage (two story) for my toys, including my truck(s). I oriented the garage with the SHORT side @ the driveway and put two 8H x 9H doors on the end (plus another 7H x 8W on one of the sides for lawn equipment coming and going) so that, when I pull in the garage, I have 36' of depth.
For orientation, I installed a laser light that connects to the garage door opener. Open the GDO and the laser turns on for a minute. You park your vehicle in the garage EXACTLY where you want it, then you aim the laser beam to a recognizable spot on your dash. When I pull in the garage to park, I pull in just far enough so the laser beam shines in the exact same spot on my dash that I set it up for. That way, I know I'm EXACTLY where I need to be so I can safely close the door. No guesswork.
Well my 2018 F250 4x4 CCSB is on order, my door height is OK,, my garage is 40' deep ( was a 4 car, now 3 car ) I've always parked bike, snowmobile, atv, boat in garage since I learned to drive.. A buddy bought a F150 short box ( 5 1/2 foot ) because anything longer wont fit - Now he hopes to pull a 30' TT... we will see how that works.. In my area - I don't even lock our doors - so security is not a issue,, just weather.. Guess I'd rather have a truck to fit my needs, even if it sits outside sometimes..
I did that back in 1994 with my super cab long box Eddie Bauer. Even had to notch the studs. I measured carefully and checked the guides from Ford. What they never said was 4x4 trucks had a different front bumper with nostrils that stuck out another 1-1/2". Nothing like cutting the studs on a day where the high was -15. Of course, the previous day I drove 600 miles to get the truck at the dealer, and the high was -22 actual temp. Do what you gotta do. My trucks never sit out overnight.
I had to do something similar. Mine will only fit while backed into the garage. I used the 4x4 on the floor like you did so I back up as far as possible (actually into the rear wall). I then have to set the parking brake or it will roll forward too far when I put it in park. I have about 1" to spare when I close the garage door.
After removing the studs and adding a header.
The finished product.
