Lance 825 and Battery Charging Help - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Towing Forum > Slide-in / Truck Campers
Reload this Page > Lance 825 and Battery Charging Help
Old 04-16-2018, 05:52 PM
Ziggy81's Avatar
Ziggy81
Ziggy81 is offline
Ziggy81 is starting off with a positive reputation.
Looking for some help with the my new 2018 Lance 825 and 2016 F250 6.7. The truck doesn't seem to be charging the camper battery. I ran the battery almost empty this past weekend where my atwood Jacks wouldn't even operate so I turned on the truck, let it run for a while and still didn't have the power to operate the jacks, so I manually jacked them. I then drove home for 3 hrs and checked the battery, still barely had a charge.
I have the lance plug installed and tied into the tow harness on the truck, and verified today that all fuses and relays are good. Note that I was also pulling a car trailer if that matters.
Any ideas?
Old 04-16-2018, 08:43 PM
HRTKD's Avatar
HRTKD
HRTKD is online now
HRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud of
At least on the 2017+ you have to connect the harness, start the engine and then press the brake to get the charging circuit engaged. If the truck doesn't detect something there then the charging may not happen.
If your battery is severely discharged it could take a looong time to charge. A dedicated A/C charger is probably your best bet.
Old 04-17-2018, 12:00 PM
Ziggy81's Avatar
Ziggy81
Ziggy81 is offline
I'm not sure if the brake pedal thing applies to 2016...
Old 04-17-2018, 06:55 PM
Seabiscuit-P3's Avatar
Seabiscuit-P3
Seabiscuit-P3 is offline
Seabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputation
I'm presuming that you you've checked the plug to make sure there is power on that pin?
My pickup and our 1997 Lance 880 Legends are antiques compared to what you have, but...
  1. there was a fuse in the box under the hood that was blown, preventing the camper battery from charging.
  2. There were two fuse boxes inside the camper...
  3. The only other problem we ever had was if I left the refer on 12 volt, apparently the 12 volt supply of power from the pickup couldn't keep up with it. Starting out with a full battery in the camper, after a 250 mile trip the battery was only about 1/2 charged. Turn the refer off, and there was no apparent drain on the battery.
I have essentially the same problem with our current 2005 Alpenlite Limited Santa Fe 1150 1 year old to us & came with a 1 year warranty.
It uses the exact same "Lance" plug set up. Pickup charging system has been double checked and is just fine. We did have a problem with the Converter/Inverter in the camper and it was replaced by the dealership and I still didn't notice any difference. The dealership adjusted something on the refer so we'll see what goes on now. Haven't made a trip or tried it out since the refer adjustment.
I carry a jumper pack with us. I can hook it up to the camper batteries and use it for the jacks, which I've never had to do, or use it to provide power to start the generator which I have had to do.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
