Broke off EZ out - Ford Truck Enthusiasts Forums
Broke off EZ out
Old 04-16-2018, 05:16 PM
GeneGregory
GeneGregory is offline
GeneGregory is starting off with a positive reputation.
Broke off EZ out
Well I was out bleeding the brakes on my truck today (F350) and got to the right front and broke off the bleeder valve in the caliper then against my better judgement I got out my EZouts and broke the EZout off in the broke off bleeder. So its time to stop before I make things even worse and ask what would you guys do next before I frick things up even more.
Old 04-16-2018, 05:30 PM
Dave145's Avatar
Dave145
Dave145 is offline
Dave145 is starting off with a positive reputation.
I'd replace the caliper you broke the EZ out in, and use it as an excuse to replace/rebuild the other caliper as well.
deich's Avatar
deich
deich is offline
deich is starting off with a positive reputation.
New caliper?
Old 04-16-2018, 05:34 PM
jakeharp's Avatar
jakeharp
jakeharp is offline
jakeharp is gaining momentum as a positive member of FTE.
Ehh.....
That sucks man, ive never had an EZ out actually work for me before i stopped cuz it was ready to snap..... If your not hip on replacing caliper right out of the gate, you can drill out, tap-re-thread/heli coil, but I dont know how that would work with a bleeder hole, seeing the screw needs to sit married to the cavity in order to seal .............
Old 04-16-2018, 06:19 PM
Filthy Beast's Avatar
Filthy Beast
Filthy Beast is offline
Filthy Beast has a very good reputation on FTE.Filthy Beast has a very good reputation on FTE.Filthy Beast has a very good reputation on FTE.Filthy Beast has a very good reputation on FTE.
Another vote to replace the caliper. Drilling out an "EZ OUT" is more trouble than it's worth.
Old 04-16-2018, 06:21 PM
JRT812's Avatar
JRT812
JRT812 is offline
JRT812 is starting off with a positive reputation.
bummer man and I have learned my lesson with the EZ Outs. Start from scratch like others have said.
Old 04-16-2018, 06:32 PM
scottscott
scottscott is offline
scottscott is gaining momentum as a positive member of FTE.scottscott is gaining momentum as a positive member of FTE.
Its crude, may not work, & probably isn't the safest, but....
A couple of times I've run in to the same problem. I've been able to get the brake hose loose where it goes in to the caliper & have been sort of able to bleed the air out. Gravity bleeding seems to work best in this situation. Barely crack the hose so fluid just oozes out. Let it sit for a while, making sure the master doesn't run dry. Tighten the hose up, & hope for the best. When its late at night, the parts stores are closed, & you have to be on the road early in the AM you have to to what it takes.
Of course, a new caliper with a functioning bleeder is the correct way to go.
Old 04-16-2018, 07:34 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
Jklnhyd is a splendid one to beholdJklnhyd is a splendid one to beholdJklnhyd is a splendid one to beholdJklnhyd is a splendid one to beholdJklnhyd is a splendid one to beholdJklnhyd is a splendid one to beholdJklnhyd is a splendid one to behold
Use a grinder and grind the top of all the bad stuff, relatively flat. Then take the smallest drill bit that you have and very softly, start drilling down through the very center of where the hole should be. If you are off a bit, manipulate the bit until it is centered. Keep using bigger drill bits, and make sure you dont touch the original threads.
I have done this hundreds of times. I would rather try this than just pony up for calipers.
Old 04-16-2018, 09:35 PM
54Hydro
54Hydro is offline
54Hydro is starting off with a positive reputation.
Drilling tool steel is a royal pain in the ****. You could try breaking the broken piece of the extractor with a center punch, doesn't always work. What type were you using? The spiral fluted style or straight?
Old 04-16-2018, 09:51 PM
GeneGregory
It was a spiral fluted the kind you screw in counter clockwise.
Old 04-16-2018, 10:28 PM
meangreen92's Avatar
meangreen92
meangreen92 is online now
meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.
Can you access the bleeder screw from behind, if you pop the piston out of the caliper?
Old 04-16-2018, 10:48 PM
78Broncoinpieces
78Broncoinpieces is offline
78Broncoinpieces is starting off with a positive reputation.
you can grind an EZ out with a stone or carbide bit. it will be a slow process. drilling with a regular drill bit ain't gonna happen. the EZ is too hard of a material for drill bits.
Old 04-17-2018, 08:43 AM
speedfreak78
speedfreak78 is offline
speedfreak78 is starting off with a positive reputation.
To try and get out the EZ out, use a center punch and try to shatter the EZ out. If that works, you'll need to flush out the caliper really well to get any small shards of metal out. Otherwise you'll need a carbide drill/ endmill to drill it out. Looks like a reman caliper would be $75-100. I'd just swap calipers, not worth the time or hassle at that price.
Old 04-17-2018, 10:52 AM
JD Q
JD Q is offline
JD Q is starting off with a positive reputation.
This is after the fact but a good set of left handed drills is a good thing to keep handy for removing plugs, screws and such. Just use the drill counter-clockwise on center, start small and work up 1/32" at a time to the minor thread diameter. Typically the thread will unscrew its-self out of the hole when the drill catches with enough force. https://www.northerntool.com/shop/to...SABEgJ7RPD_BwE
However now, if you broke a well-made easy-out, it will need to be ground out or broke out. If you do get it out, you can always get a bleed screw that's a little larger.
A new caliper is the easiest path to take.
Old 04-17-2018, 02:14 PM
JakeHan
JakeHan is offline
JakeHan is starting off with a positive reputation.
Weld a nut to it and screw it out, then get a new bleeder screw - if nothing else, the heat'll help knock it loose. Or, warm it with a torch and take it out using vice grips, if it isn't broken off flush.... There's a pretty good chance you'll break it off if it's that stuck, at which point it's time for a new caliper anyhow.......
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
