Broke off EZ out - Page 2 - Ford Truck Enthusiasts Forums
Broke off EZ out
Old 04-17-2018, 02:24 PM
54Hydro
54Hydro is offline
54Hydro is starting off with a positive reputation.
Originally Posted by GeneGregory View Post
It was a spiral fluted the kind you screw in counter clockwise.
Those should really only be used on thick material. They expand thinner material and just anchor it tighter.
Old 04-17-2018, 02:28 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
ya ive had them spirals tighten up when i drill the walls of bolts thing too.
Old 04-17-2018, 04:20 PM
Aaron-71's Avatar
Aaron-71
Aaron-71 is online now
Aaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to behold
Before you go too far with replacing the caliper, try taking it to a shop and asking them to remove the easy out for you.
I had a shop remove a broken easy-out from my cylinder head (broken exhaust bolt) for $50. Well worth it, and they didn't have to helicoil it.
Old 04-17-2018, 06:28 PM
GeneGregory
GeneGregory is offline
GeneGregory is starting off with a positive reputation.
Got 2 rebuilt calipers for the front today, going to let the rebuilder deal with the broken bleeder and EZout.
Old 04-17-2018, 07:30 PM
black & blue 78/9
black & blue 78/9 is offline
black & blue 78/9 is starting off with a positive reputation.
Broken ez
They make ez out extractors. You buy them more so at an industrial supply house. They will need to know how many flutes and what size. They work really good. As for what to do eith your current caliper. Keep it and remove broken pieces.
Remove hose so brake fluid can expand.
Heat the bleeder/ ez with a torch, use two small punches and incert into the flute area and slowly twist. You want to heat this up very hot. I have used this method a few times on feild finds that have been sitting along time.
LeoJr
03-31-2012 09:08 PM
bigtexan99
03-02-2012 09:12 AM
///M Puller
1999 to 2016 Super Duty
10-19-2008 07:57 PM
psd tuner
03-12-2007 06:30 AM
Elk6969
1978 - 1996 Big Bronco
08-21-2002 08:04 PM
Quick Reply: Broke off EZ out
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
