1948 Ford F1 Horn Question - Ford Truck Enthusiasts Forums
Old 04-16-2018, 04:11 PM
pezsox's Avatar
pezsox
pezsox is offline
pezsox is gaining momentum as a positive member of FTE.pezsox is gaining momentum as a positive member of FTE.
Ok...I am baffled. I have seen the diagram below, and I have seen the picture below. Does the nut go on inside the horn "cup" or does the horn "cup" sit on top of the nut? If it goes on before the cup then what holds the cup? The diagram doesn't show it that way.
Old 04-16-2018, 06:11 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is online now
FortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud of
[Edited]
Don't read this when the correct answer is two posts down.
Old 04-16-2018, 06:21 PM
pezsox's Avatar
pezsox
pezsox is offline
what holds the support cup and the assembly in the steering wheel opening? The reason I ask is that this I have the nut as tight as I can to the wheel. If the support cup goes over the net, my horn button is to high above the center of the wheel and technically it isn't being held be anything? That is why I loaded the pic where the poster had used the nut to hold the cup into the center of the wheel. That makes sense to me, because that would hold that support cup in. still confused
Old 04-16-2018, 08:29 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold
The exploded diagram is incorrect. The cup is retained by the steering wheel nut.
Mark
Old 04-16-2018, 09:09 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Journeyman Apprentice
Mixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud of
Mark is correct. The nut holds the cup. I just looked at mine and that's the way it's done.
Old 04-16-2018, 09:54 PM
pezsox's Avatar
pezsox
pezsox is offline
Thanks gents. For the life of me I could not figure out how it could work if following both diagrams! Once again you solved a stupid riddle!
Old 08-01-2018, 01:25 PM
GoldCo's Avatar
GoldCo
GoldCo is offline
GoldCo is gaining momentum as a positive member of FTE.GoldCo is gaining momentum as a positive member of FTE.
Thanks
Good timing ó glad to have found this thread, as I was going by the exploded diagram, too.
Old 08-01-2018, 01:28 PM
GoldCo's Avatar
GoldCo
GoldCo is offline
Also, I assume the PO just added these two rubber washers on his own accord for some reason? I donít recall where they were exactly since itís been two years since I pulled it all apart.
Old 08-01-2018, 08:49 PM
FortyNiner's Avatar
FortyNiner
They're not stock.
Old 08-02-2018, 03:41 PM
3twinridges's Avatar
3twinridges
3twinridges is offline
3twinridges has a great reputation on FTE.3twinridges has a great reputation on FTE.3twinridges has a great reputation on FTE.3twinridges has a great reputation on FTE.
I would be concerned using a rubber washer on the steering wheel nut connection. It might loosen over time or degrade leaving a loose connection.
JB
Old 08-06-2018, 06:22 PM
GoldCo's Avatar
GoldCo
GoldCo is offline
thanks...
didn't realize my horn button (plastic top cap) had broken "latches" for the clip/spring. GRRRR.
one more thing to buy (shipping will probably be as much as button).
kens65fb
06-17-2017 01:09 AM
BigBlueCat
09-17-2012 03:16 PM
mike panco
01-10-2012 10:10 AM
NtShade
09-10-2011 12:50 AM
GormGorm
04-05-2010 12:21 AM
Quick Reply: 1948 Ford F1 Horn Question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
