Rear Disc conversion
OK so the time came to upgrade the rear brakes on the 49F1. So when i was over in the USA in March i paid a visit to Summit in Sparkes where i got a SSBC conversion kit. Was going to post it back to the UK but didnt get around to it so split the package and repacked it into mine and my wifes hand luggage to carry on the plane. Any way. finally got around to fitting it last weekend and apart from having to spin about 5mm off the drive shaft flange this was an easy kit to fit and what a novelty it is to have positive braking. Would thoroughly recomend this conversion kit if your looking to up grade from drum brakes.
I also got a B&M oil cooler for the newley rebuilt Th400 trans which is doing a great job.
Next weekend is to fit the block hugger headers which also came back as hand luggage.
I used to be a hands-on General Manager for a major aftermarket suspension manufacturer.
I have over 20 years experience with their rear disc stuff. Their kits in general are "concepts" which
usually require redesign by the installer...... and a lathe, MIG, TIG, end mill, drill press, rotary table,
band saw, etc. I've never considered SSBC stuff to be "bolt-on" by any stretch of the imagination.
troy676
20
03-09-2013 08:31 AM
shermy2296
04-11-2006 09:03 PM
tack338
05-15-2003 01:02 PM
