3/4/5 series trucks - Ford Truck Enthusiasts Forums
3/4/5 series trucks
Old 04-16-2018, 11:22 AM
toddb1
toddb1 is offline
toddb1 is starting off with a positive reputation.
3/4/5 series trucks
Looking for some constructive input on these trucks for a slide in camper with the ability to tow. I sold my '16 F250 CCSB 6.7L 4x4 and toy hauler and would like to move to a truck camper package that I can tow my 7x16 tandem flat trailer with either my SXS at 1200lbs or bracket car at 2500lbs. I really like the AF 992 and I'm guessing wet it's going to come in at close to 5Klbs. I'd also like to just get a flatbed for a bit of external storage, not a great deal of weight but some bulky camping items.
So some options I have found are
A: '17 F550 CC 6.7l 4x4 with a monroe hauler flatbed. I'm sure it's plenty of truck but it's also pretty pricey and has 19.5s with 4.30 gear.
B: '17 F350 4x4 6.7l CC with a CM aluminum flatbed, price is better same trim package as A but probably going to run close to max GCVW, 17"wheel with 4.10s.
C: '15 F350 4x4 6.7l CC DRW regular bed, used so price is the best. I think it has a dana 80 with 3.73, I'd have to change the bed down the road or transfer stuff onto the trailer which wouldn't be a big deal.
A/B I feel are over geared, with the heavier load it'll be pretty flat highway travel. With the SXS into the hills 6-7% grade. The 16' pulled them in 4th at about 18.5Klbs in the heat with 3.55s, 5th gear when it was cooler out.
Insurance seems to be an issue on the 4/5 series, state farm seems to go by GVW but I think it's doable without commercial policy. AZ will screw all these on registration due to weight.
I think all 3 will do the job, all have plenty of power for me and cheapest usually wins but are the other two worth the extra $?
Thanks
Todd
Old 04-16-2018, 10:45 PM
Superdave71
Superdave71 is online now
Superdave71 is gaining momentum as a positive member of FTE.
Id wonder if the Artic Fox will fit on the flatbeds?
Old 04-16-2018, 11:17 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is offline
Alaskan_Warbird has a good reputation on FTE.Alaskan_Warbird has a good reputation on FTE.
I like my truck (in sig.) and just put a 2015 Host Mammoth camper on it today, actually. I have a 6,114 pound payload and am running the 6.2L gas engine. I'll eventually haul a utility trailer behind it with a couple of 4-wheelers. Even w/o a trailer, I found I do want airbags because of how tall the TC is and how that moves the CoG up out of the bed. YMMV.
Good luck and let us know what you go with!
Old 04-17-2018, 04:08 PM
bobv60
bobv60 is online now
bobv60 has a good reputation on FTE.bobv60 has a good reputation on FTE.
Have you looked at the f450 pickup?
Old 04-18-2018, 08:55 AM
toddb1
toddb1 is offline
Hey the AF looks good for a flatbed, like all of them it's how far forward it'll go until stuff gets in the way. The 990 i looked at has two diagonal braces for the bumper, may be easy enough to modify the bed to slide it up on a 9' bed.
The 450 conundrum, with a factory bed the CCC is less than a DRW 350. They are still a 14K truck unless I do cab and chassis and up it to 16K. The 17s+ have larger rear axle, wide front axle, larger brakes and those cool 19.5s . The 4/5 series trucks I'm having a lot issues with insurance, when they want to do a personal policy it's $2600/yr compared to ~900.
I'm thinking the 15s are the way to go, can't see I enough benefit to the larger truck for this package.
Lord Vokk
12-17-2016 06:41 PM
Nseal1996
35
07-11-2012 03:52 AM
fordtruckman91
Large Truck
01-16-2012 12:41 AM
rosco351
Modular V8 (4.6L, 5.4L)
06-02-2002 10:47 PM
fastow
1997 - 2003 F150
05-28-2002 01:37 AM
Quick Reply: 3/4/5 series trucks
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
