99 windstar power windows - Ford Truck Enthusiasts Forums
Old 09-18-2003, 06:15 AM
vicbulge vicbulge is offline
vicbulge is starting off with a positive reputation.
I've read some posts on power windows and didn't see anything pertaining to my situation. My passenger window doesn't work with the master or the dedicated switch. Recently, either 1 or both rear vent windows has been intermittently inop. They both work now, and I regularly excersize them to make sure they keep working. As far as the relays go, is there 1 that would control just the pax window, or is it possible that the single circuit in a multi circuit relay or module is bad? Looking for troubleshooting tips. power mirror works fine on that door, and there are no other electrical malf's at this time. Thanks, and nice to be here!
_________________________
1999 Windstar SE 3.8
Old 09-18-2003, 06:31 AM
stepman stepman is offline
stepman is starting off with a positive reputation.
Sounds like your motor died in the pass door. Don't know of an easy wat to tell. Have to pull connector and see if it gets power when you hit the switch I think.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
