Long cranking + 5-10 sec or no start - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
  #31
Old 05-14-2018, 10:51 AM
Josh Rowe Sr.'s Avatar
Josh Rowe Sr.
Josh Rowe Sr. is offline
Josh Rowe Sr. is starting off with a positive reputation.
how's the cam sensor??
  #32
Old 05-14-2018, 07:43 PM
purplewg's Avatar
purplewg
purplewg is offline
purplewg has a good reputation on FTE.purplewg has a good reputation on FTE.
Not sure Josh. I don't no of any good way to test it. Probably easier to just replace it. Never hurts to have a spare anyway. I always had a spare in Jeep.
  #33
Old 05-14-2018, 07:46 PM
Josh Rowe Sr.
Had same issue when I woke up this morning, changed cam, cranked right up
  #34
Old 05-20-2018, 07:03 AM
purplewg's Avatar
purplewg
purplewg is offline
Just another update. I do have the new cam sensor sitting here on my desk but not sure I am going to put it in right away. The more I drive the truck after replacing all the other stuff I listed the better it is getting. The last thing was the IPR sensor I changed. I really need to get the truck out on the road rather than just running it around the farm here but have been busy with other stuff. The truck is now starting within what seems to be a second or two. I probably with go ahead an change the cam sensor as the one that is in it is original and 18 years old.
  #35
Old 06-12-2018, 10:57 PM
gdmafia
gdmafia is offline
gdmafia is starting off with a positive reputation.
Update
Had some time to tinker with it, starts and run fair, but have a knock when at operating temp. I don't think it's a mechanical knock as it's louder when warm and I can feel the pulsing in the lines for the fuel cross over.
I replaced the ICP in the head, I rebuild the new IPR in the oil pump, I checked injector hold down bolts torqued to spec, I checked all plugs and connector, I checked height of injector and found #6 sit a little higher than the rest, pulled it, didn't look like any blow by of any kind, replaced orings and checked for copper washer in cup, nothing, reinstall and still sit high. I do have small amount of oil sitting in front part of valley, but not wet to the back. I change the spring in the fuel cross over to the lightest only felt like little less power and for sure little higher exhaust temp 50-100.
Is it possible it's the new Terminator hpop or do I start pop all the injectors, got new orings for all just in case, also has old hpop.
  #36
Old 06-13-2018, 12:06 AM
hydro man 17
hydro man 17 is online now
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
As far as the long cold crank is concerned, have you checked to see if the HPOP reservoir is full before you try to start? If the check ball leaks and the oil level is down in the reservoir it could be part of your long crank issue.
  #37
Old 06-13-2018, 01:01 AM
gdmafia
gdmafia is offline
The check ball, that should been replaced/tested as they build the hpop at terminator. I send them my old pump and it is the same I got back looking new and nice.
  #38
Old 06-13-2018, 11:03 AM
brian42's Avatar
brian42
brian42 is offline
brian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud of
I won't make any assumptions but they way I read it hydro man 17 might be referring to the check ball in the block.
IIRC it's on the drivers side and is an anti-drain back to prevent the HPOP reservoir from draining back into the sump when the engine is turned off and there's no oil pressure.
  #39
Old 06-13-2018, 12:38 PM
hydro man 17
Brian42 is correct. Apologizes for not being more specific.
  #40
Old 06-13-2018, 07:35 PM
gdmafia
gdmafia is offline
Ok, so is that likely it got damage when I replaced injector and hpop?
  #41
Old 06-14-2018, 09:51 AM
brian42's Avatar
brian42
brian42 is offline
No, not likely at all.
It's in the engine block. It's not likely that it's failed (or leaking by) but it has happened.
iridius
1997-2006 Expedition & Navigator
05-18-2016 02:31 PM
Greywolf
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
22
04-05-2015 02:52 PM
mechelement
01-14-2013 09:26 AM
95frd
12-22-2002 03:20 PM
97 awd xlt blue
09-21-2002 06:42 PM
Quick Reply: Long cranking + 5-10 sec or no start
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
