Fuel gauge
Fuel gauge
I’ve posted a few thing on here about my rewire and now I’m about done I’ve noticed that my fuel gauge is erratic. It’s fine until I start driving, I’m assuming it is because it’s an unbaffled tank and the slosh is causing it. I know the 65 wiring harnesses or gauge compensated for the slosh by only reading ever so often, so is there a way to recreate this effect or is it suck it up butter cup?
Not familiar if replaced with aftermarket kit. The original used a Constant Voltage Regulator usually attached to the back of the instrument cluster that monitors voltage fluctuations from between 0-10 volts to the instrument gauges. Usually can tell if the CVR is faulty if the other gauges are also acting up. If aftermarket possibly similar item in kit?
Not sure "unbaffled tank" if have not done so, suggest check the sending unit float replacements run around $5. Also check the fuel gauge circuit.
If of the plastic CC type cluster then may find attaching a ground strap from metal portion of cluster to ground will help?
Anyhow, food for thought??
Originally Posted by Shane Carruth
it is just a different gauge.
beckman
07-10-2014 11:39 PM
