How many inches drop hitch would be most favorable ... - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Towing Forum > Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
Reload this Page >
Old 04-15-2018, 09:29 PM
Larrymac52
Larrymac52 is offline
Larrymac52 is starting off with a positive reputation.
for a stock height 2018 F350 with 18” Tires
Old 04-15-2018, 09:53 PM
Superdave71
Superdave71 is offline
Superdave71 is gaining momentum as a positive member of FTE.
That’s a loaded question. Depends on your trailer. The goal is to keep it level.
Old 04-15-2018, 09:54 PM
jetjockey99
jetjockey99 is offline
jetjockey99 is gaining momentum as a positive member of FTE.jetjockey99 is gaining momentum as a positive member of FTE.
Depends on the trailer tongue height. You want the truck and trailer near level when hooked up. On my F350 Dually, most trailers are close to level with a 4 inch drop.
Old 04-16-2018, 05:15 AM
psdxohio
psdxohio is offline
psdxohio is starting off with a positive reputation.
Here’s how to accurately determine what you need: https://www.etrailer.com/faq-ballmount.aspx
Old 04-16-2018, 05:19 AM
David7.3's Avatar
David7.3
David7.3 is offline
The Lost One
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Nice post, good site. My 4 inch drop on my 08 handles just about any trailer.
Old 04-16-2018, 07:18 AM
Larrymac52
I don’t have a trailer now. But wanted a hitch thst can be adjusted to handle most normal applications for my stock height ‘18 F350 with 18” wheels.
Perhaps I should have asked what “adjustable” drop hitch would handle most normal applications for my F350.
Old 04-16-2018, 08:02 AM
psdxohio
psdxohio is offline
The top inside of the receiver on my F150 was 19” and the top inside of the receiver on my F250 is 23”. Be aware that 2017+ Super Duty truck’s sit higher than 2016 and earlier. I bought an adjustable hitch that goes to an 8” drop. It arrives today.
Old 04-16-2018, 11:57 AM
cattaco
cattaco is offline
cattaco is starting off with a positive reputation.
I bought a 6" and debated an 8". Glad I didn't get the 8", they get so low to the ground.
Old 04-16-2018, 01:11 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
I have a 2017 F-350 that I bought the 8" adjustable hitch for. I could have got by with 4" but I think my RV trailer's coupler is a bit taller than most. For my ATV trailer (single axle) a 6" drop is just about right.
Old 04-16-2018, 04:24 PM
CarterKraft's Avatar
CarterKraft
CarterKraft is offline
CarterKraft has a good reputation on FTE.CarterKraft has a good reputation on FTE.CarterKraft has a good reputation on FTE.
Bought a 8" for my 350 DRW, if its too long I will shorten it in the chop saw...
Old 04-16-2018, 07:55 PM
psdxohio
psdxohio is offline
In the lowest setting the clearance to the ground is 9”.
Old 04-18-2018, 12:17 AM
zekes66
zekes66 is offline
zekes66 is starting off with a positive reputation.
I have a 17 F250. This is the shank I got from Blue OX. Its the 2.5 shank and 9" drop. My WDH head is on the bottom hole and the 31' trailer sits level.
Weight Distribution Shank 7 Hole x 9" 2-1/2" Receiver | Blue Ox | Blue Ox
Old 04-18-2018, 04:58 AM
psdxohio
psdxohio is offline
Weight Distribution Shank 7 Hole x 9" 2-1/2" Receiver Blue Ox Blue Ox
Just a point of clarification - this shank is 9” Long, has 8-3/4” of vertical adjustment, and the drop is 2”.
https://www.etrailer.com/Accessories-and-Parts/Blue-Ox/BXW4018.html?feed=npn&gclid=EAIaIQobChMI8LLuicfD2g IVUtbACh0gZQCEEAQYASABEgKdGPD_BwE
Also....how far from the ground is the top of the hitch ball when installed on your truck?
cherokeexj32
1968-2013 Full Size Vans
20
07-23-2013 06:34 AM
cherokeexj32
07-08-2013 10:50 AM
1986F150six
Trading Feedback
02-07-2012 12:34 PM
HankMurphy
2009 - 2014 F150
11-29-2008 08:40 PM
79monster
11-05-2001 02:23 PM
Quick Reply: How many inches drop hitch would be most favorable ...
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
