Has the radiator issue been fixed on the 17/18s? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 04-15-2018, 07:30 PM
sundownnc
sundownnc is offline
sundownnc is starting off with a positive reputation.
Hey all - sorry, I've paged through 12 pages when searching through results for "radiator" in this particular forum, but I can't find the answer to my question (so apologizes if I've missed it somehow).
I'm hoping it's an easy (and positive) one: Has the "leaky" radiator (lower driver's side) issue been fixed on these newer trucks? I have a 2015, and it's just developed a small leak. I'm at a point where I'd traditionally trade the truck in anyway, and am looking at an '18 SD, but I may have second thoughts if they're still producing these trucks with the same known issue since 2008 (I think?). Yes, extended warranties cover these things, but I consider it akin to negligence if Ford continues down a path that they know eventually results in $1700 - $2200 radiator fixes somewhere between 50k and 90k miles.
Appreciate any input you may have.
Old 04-15-2018, 08:31 PM
UGA33's Avatar
UGA33
UGA33 is offline
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
They are using the same radiators on the new trucks, but the fully boxed frame, extra crossmember up front, and the new body mount bushings should fix the major issue that caused most of the radiator failures on the 08-16 trucks which was frame flex and how they were mounted. Haven't personally seen a thread or instance of a 2017+ with a leaking radiator yet.
Old 04-15-2018, 08:43 PM
psdxohio
psdxohio is offline
psdxohio is starting off with a positive reputation.
Which motor are we talking about? 6.7 or 6.2?
Old 04-15-2018, 08:46 PM
UGA33's Avatar
UGA33
UGA33 is offline
If we are talking radiator issues, it would have to be a 6.7
Old 04-15-2018, 08:54 PM
sundownnc
Correct. 6.7. Appreciate the insight guys. My '15 sees plenty of farm work and twisty/bumpy roads.
Any other thoughts are certainly welcome.
Old 04-15-2018, 11:20 PM
TheLex's Avatar
TheLex
TheLex is offline
TheLex is gaining momentum as a positive member of FTE.TheLex is gaining momentum as a positive member of FTE.
Yup, friend of mine has a 2014 F250 6.7 and just developed a slow radiator leak. $1500-1700 for a new one.
He's going out and buying a new F350 CC DRW .
Old 04-16-2018, 06:36 AM
SloScooter
SloScooter is offline
SloScooter is starting off with a positive reputation.
Sundownc any association with the audio company?
Old 04-16-2018, 06:49 AM
sundownnc
Afraid not.
Old 04-16-2018, 07:19 AM
FOUNTAIN 1's Avatar
FOUNTAIN 1
FOUNTAIN 1 is offline
FOUNTAIN 1 has a good reputation on FTE.FOUNTAIN 1 has a good reputation on FTE.FOUNTAIN 1 has a good reputation on FTE.
Many experiencing coolant smell. And refilling of coolant. Havenít found where itís coming or going from. My truck was due ikr was due in shop for three separate problems. That being one of them. Good luck.
Old 04-16-2018, 08:40 AM
honda250xtitan
honda250xtitan is offline
honda250xtitan is starting off with a positive reputation.
my uncle had a cracked radiator fixed on his 17 platinum a few weeks ago
Old 04-16-2018, 09:09 AM
troverman's Avatar
troverman
troverman is online now
troverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud of
I agree with Josh. The previous generation trucks tended to have radiators leak from frame flex. Even guys that replaced the OEM radiator with expensive Mishimoto radiators had the same issue happen to them. Powerstroke help showed an episode where they lifted on front tire with a fork truck to give an extreme example of flex...you can see the tug at the radiator corner. It seems the problem could be solved with rubber bushings that have more travel, but Ford never corrected it on these trucks. Not all of them had the problem...probably depended upon terrain, etc.
SO, as Josh said, the new trucks have a fully boxed frame end to end, with new body mounts. The flex is greatly reduced, which should cause much less tugging on the radiator. Time will tell, but I don't have a concern.
Old 04-16-2018, 12:04 PM
Buliwyf
Buliwyf is offline
Buliwyf is gaining momentum as a positive member of FTE.Buliwyf is gaining momentum as a positive member of FTE.
Shouldn't have any tugging on the radiator.
That's a pretty monstrous design flaw. Wow. Hopefully the 17+'s are good to go. I'd mount the radiator inside an inflexible steel frame, and float that to the chassis or body with rubber.
Old 04-22-2018, 03:28 PM
Deadbuck
Deadbuck is offline
Deadbuck is starting off with a positive reputation.
I replaced 5 radiators on my 2012, traded it in with 200,000. Upgraded to a 2017 and currently have 48,000 miles no leak yet.
Old 04-30-2018, 09:39 PM
Truckie256's Avatar
Truckie256
Truckie256 is offline
Truckie256 is gaining momentum as a positive member of FTE.
re: Coolant smell
I have owned 2- 6.7 SD trucks......Both of them had a leak from a coupling ON TOP of the engine... Was told like a $5.00 part that costs $800 to replace... I ended up with a lake of Coolant on top of the engine. Every time truck heats up u smell it in the cab...
THIS TIME I BOUGHT THE GASSER
Old 05-01-2018, 07:20 AM
cficare's Avatar
cficare
cficare is offline
cficare has a good reputation on FTE.cficare has a good reputation on FTE.
If you're talking about 2017+ models, there is another thread which addressed ghost coolant leakage ... could smell it but not see it. They determined it to be a T-fitting located on top of the engine with loose hose connection. The leak was so fine that it would evaporate before leaving any visual trace. Good luck to you, too.
Quick Reply: Has the radiator issue been fixed on the 17/18s?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
