Will this oil pan work?
Yes all will work! I put a ‘77 460 out of a F350 into my ‘77 F150 4x4.
If I remember correctly that kit didn’t come with the nut for the main cap bolt for the oil pick up tube. No big deal. Just a hardware store run to get one.
As mentioned you need to drill out the corner oil pan holes to 5/16” as well as the oil pan gasket if I recall correctly.
I really need to put a rear sump on mine. I currently have a front sump and it is very, very dented.
On a side note, when you install that, can you measure from the trans to where the rear sump is? My exhaust crosses over in that area and I need to know if my exhaust will need to be rerouted.
Please and thank you.
Help me understand this, are u taking about mounting the bracket on the pick up tube to crank main cap? To do that I would have to remove old main cap bolt and replace with this special stud. Is that just a simple remove and replace and torque to spec or do I have to do something special since that is main bearing cap? Also in the pic I attached in post that pick up tube has no mounting bracket? Has some on here used this and can tell me if pick up tube does indeed mount to main cap?
