2017 F-250 Water Separator Drain Valve Install - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 04-14-2018, 06:22 PM
Aggie2014
Aggie2014 is offline
Aggie2014 is starting off with a positive reputation.
I recently drained the water separator on my 2017 F-250 and broke the two plastic tabs on the yellow valve when attempting to shut the valve. The yellow drain / plug did fully close and has remained sealed for a few days. Went ahead and ordered a few replacement valves and went to install the new one today, but am having issues getting the old one removed. It will turn in both directions but will not come off and feels stripped. Anyone by chance ran into this issue before? Wondering if I'll need to replace the whole water separator or if there is a way to get the drain off. Any advice is really appreciated!
Old 04-15-2018, 10:17 AM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
I believe the only thing holding it in, other than the broken off tabs, is friction from an O-ring, Turning it counter clockwise while pulling down should get it out.
Old 04-15-2018, 10:21 AM
David7.3's Avatar
David7.3
David7.3 is offline
The Lost One
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
That is correct, the o-rings are the only thing holding it in, they also dry out under the truck making the valve hard to turn, I spray PB blaster on it and wait a few before changing or draining and of the filters downstairs.
Old 04-17-2018, 10:41 PM
Redrockerstl55's Avatar
Redrockerstl55
Redrockerstl55 is online now
Redrockerstl55 is gaining momentum as a positive member of FTE.Redrockerstl55 is gaining momentum as a positive member of FTE.
Maybe the video I completed today may help.
Old 04-18-2018, 10:52 AM
MJMETHOW
MJMETHOW is offline
MJMETHOW is starting off with a positive reputation.
Do you have the part # ? Going to keep a extra on hand.
Thanks Mike
Old 04-20-2018, 04:21 PM
Aggie2014
Thank y’all for all of the help! Was able to get the valve off today and put the replacement in without issue. Thanks again!
The part number is HC3Z-9J305-A. Want to say they’re only around $5 a piece.
Gary O
2017+ Super Duty
31
06-06-2018 02:04 PM
Redrockerstl55
2017+ Super Duty
23
04-19-2018 01:35 PM
Redrockerstl55
04-17-2018 04:12 PM
SweetBearCub
1968-2013 Full Size Vans
08-07-2015 02:17 AM
clydesdale6
09-28-2010 04:54 PM
Quick Reply: 2017 F-250 Water Separator Drain Valve Install
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
