94 Ford F-350 7.3 idi lift questions - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Misc. > Offroad & 4x4
Reload this Page >
Old 04-13-2018, 08:38 PM
elramosjorge
elramosjorge is offline
elramosjorge is starting off with a positive reputation.
I have A 94 f350 I just finished lifting.
Front I went a total of 9 to 11 inch by sky manufacturing 5 inch reverse shackle and 4 to 6 inch leaf springs. ( not sure exact lift leaf springs where)
Rear I did 6 inch reverse shackle also from sky manufacturer.
how ever there is blocks here. Total of 6 inch, 2 blocks. Which I plan on swapping out with a single block from PMF with desired angle for dif to pinion.
So my questions are here with in this.
First letís start with drive shaft. I was reading that some people get away from extending it by giving there dif a 5 degree angle. This sound some what crazy because I understand pinion angle and would like to know if this is doable.
I am all about doing this right, so I already know I have to extend my drive shaft and put some type of pinion angle. My question are where do I start, measure now for drive shaft or angle etc.
jorge Ramos
Old 05-09-2018, 02:12 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.
lengthen the front shaft and change rto 1410 at pinion, that will work with your angle. shimming the pinon up will fck up your caster and truck will drive horrible on the road, only way to do that correctly is cut and turn the c's on the axle tubes
Old 06-26-2018, 09:07 AM
LONCO
LONCO is offline
LONCO is starting off with a positive reputation.
^2 I ran 1410 u-joints all around on my F250. I know it’s older but should work fine on yours. I went to jy and got driveshafts out of 95 Fsuperduty and made my own 1410 shafts
Old 06-27-2018, 08:17 PM
Ironhead280
Ironhead280 is online now
Ironhead280 is starting off with a positive reputation.
1410 points do nothing if your not set up for them your 1350's will work.
bigger U-JOINTS do nothing on mall scooter.
Old 06-28-2018, 06:19 AM
KubotaOrange76
nothing other than provide more angle, 1350's have little capability compared to a 1310 or 1410. First glance looks like that factory joint will bind or be close to bound up at ride height. I guess you could always run a tom woods offset joint
Old 06-28-2018, 07:44 AM
LONCO
LONCO is offline
A 1350 only 20 degrees, a 1410 at 37 degrees of operating angle, plus stronger.
Old 07-24-2018, 08:20 PM
Ironhead280
Seriously, just how much off roading, locked in 4 wheel drive is this Monster gonna see!!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
