2013 F350 6.7 Transmission slipping when cold - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 04-13-2018, 10:52 AM
ScottMcLean
ScottMcLean is offline
ScottMcLean is starting off with a positive reputation.
I have a 2013 f350 with the 6.7, when my truck is cold in the mornings, (trans temp at 10 degrees C) my truck will not engage when shifting, and when it does it will stick in first or jump me into 5th until a make it out of my block, then its fine until its left for a long period of time until it becomes cold again.
Anyone else have this issue? just wondering what the problem might be, i can replace parts all day, but i cant diagnose the problems. any input would be appreciated!
Old 04-13-2018, 12:34 PM
djousma
djousma is online now
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
Shift solenoid getting weak? I dont know.
Old 04-13-2018, 03:43 PM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
When and if has the tranny ever been serviced?
Old 04-14-2018, 08:48 AM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
Clubwagon is gaining momentum as a positive member of FTE.Clubwagon is gaining momentum as a positive member of FTE.
Likely what the industry refers to as "morning sickness". The internal seals (lip seals in the drums) are hard and not sealing correctly. So the pressure leaks and the drum's pressure plates don't apply so it won't shift. Or there is a cross leak that forces it into the wrong gear. Once it warms up a little the seals soften up and begin sealing again.
You need to get something like Torque Pro or ForScan to monitor the transmission. You want to see what the ECU is 'commanding'. That is: is the ECU commanding the shift and its just not shifting? Or is it not commanding the shift.
Old 04-14-2018, 08:08 PM
willydmax
willydmax is offline
willydmax is gaining momentum as a positive member of FTE.
Just diagnosing from my chair...could be the TCM is having issues. It needs to be hooked up to a scan tool and checked out while it's having issues and then given a proper diagnosis.
Old 04-14-2018, 08:14 PM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
There is a new flash out there for the trans, take it in and see if that will fix the issue.
gbrewer
01-13-2015 07:51 AM
hughjazz
1999 to 2016 Super Duty
41
09-10-2013 12:59 PM
Paul Moody
03-05-2012 07:10 AM
Bluesmokestack
12-10-2011 09:28 PM
Rick X
04-07-2003 11:24 PM
Quick Reply: 2013 F350 6.7 Transmission slipping when cold
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
