Comparing tunes from several different tuners
I am starting a new thread to focus on the tunes and close the turbo thread since the discussion is a new topic.
Truck info from signature for those using mobile view.
Swamps Stage 2 Split Shot Injectors - PHP Hydra- Gearhead, 1023, and Swamps tunes - CSD T4 mount - Borg Warner 364.5 SXE (13009097055) with 1.0 housing (179905) - Donaldson Blue 6637 - LUK 07-155 Clutch - Detroit Locker - 4.10 gears - 2008 FORD tow mirrors - CM flatbed - Truck/camper 24K - Truck/equipment trailer 18k empty 26k loaded never 26000.000001
Here we go .Multiple tunes all from today. not all apples to apples but I tried. I have my opinions from how they "feel" and the data.
Keep in mind this weighs 9500 with just me in it.
Tune #02 on the hydra Tuner #1 light tow or economy Gearhead Automotive
Boost 33 or 34
Boost 33 or 34
Tune #03 on the hydra Tuner #1 street daily Gearhead Automotive
Boost 33 or 34
Tune #13 on the hydra Tuner #2 medium tow 1023 Diesel
Boost 30 or 32
Tune #14 on the hydra Tuner #2 light tow or economy Ran out of road and had to back off. 1023 Diesel
Boost 30
EDIT adding another and tuner from this morning.
Tune #09 on the hydra Tuner #3 light tow Swamps Diesel
Boost unknown tripped ses light.
Boost 27 and climbing when I looked away at egt 1000
Boost 33 or 34
Boost 33 or 34
Boost 33 or 34
Boost 30 or 32
Boost 30
Out of all of that, pay close attention to two lines - the red one (ICP) and the green one (FIPW). They are mirror images of each other at WOT - with the centerline for the green line being right around 30 (3ms FIPW). When the FIPW goes long in each of these, the ICP suffers. ICP is the real fuel pressure - the permagrin enhancer.
Yep I was really surprised the FIPW was as high as it is in a "light tow" tune from tuner #1 That is who I have been running normally. Need to try out the other 2 more and see how they feel during normal driving.
Swamps stage II split shot is a stock injector with a 30% nozzle. There's no benefit or added power to FIPW approaching or going over 4ms. It's already emptied the injector by then and the only result you get is lower ICP as the HPOP struggles to hold the injectors open that long. The reality is you end up with lower injection pressure which can in some instances increase EGT's, smoke, and actually reduce power a bit. You'll notice that between the tunes over 4 ms vs the ones close to 3 ms, the acceleration from ~43mph to ~62mph are all almost identical. Meaning the higher FIPW isn't helping at all. Rough estimate, you're capped out at 3.3ms. Going over that starts to increase your IPR duty cycle and ICP begins to drop.
What would be curious is to see peak EGT on identical runs between those tunes to see temp differences. Of course it would be nice knowing that timing was identical for each, but I still have my money on 3.3ms or less running slightly cooler than over 4ms.
It's fun datalogging and doing comparisons.
Edit
Thank you for your analysis. That is exactly what I was hoping for.
As for the injectors I bought them used cheap. The seller didn't know what they were exactly just that they were remans from swamps so I took a gamble. Either 400 or 500 is what I paid
Another edit
Now that I think about it I'm 99% sure that the tunes with longer FIPW ran a little more egt. Like 50 degrees .
Tune 13 and tune 14 come close, but they all miss the mark. It's a very basic rule: Whichever tune gives the best ICP and holds it without the IPR escalating - that's a balanced tune with minimal EGTs. I can't speak to Start Of Injection (timing), because that little nugget isn't available to us over the OBDII port.
Cody has written a tow tune for me that locks on to 3000 ICP like glue, and my IPR never ever went above 42% with ANY of his tunes. With the race tune, the engine shreds tires and has bent metal (pre-traction bars) - but the FIPW never reaches 3 ms, let alone surpass that line.
Updated first post to name who is who. I am also open to try other options if someone wants to write me a file.
I have really only towed with the Gearhead tunes. Need to try the 1023 and Swamps towing. When I installed my injectors I had Gearhead and Swamps tunes made for them. The Gearhead had a touch less smoke so I went with them and based my decision on that part alone. Now I am going back to make an informed decision.
Can we calculate how an injector will act if we know all the specs?
XX volume with YY nozzle hole size at ZZ icp = ?? FIPW needed to empty fuel
XX FIPW with YY nozzle hole size at ZZ icp = ?? volume of fuel delivered
The worst part about seeing the GH tunes running such high FIPW for me is on a personal level. I have learned how to drive my truck on the GH tunes and when I tried the 1023 tunes recently they did seem faster and more power, but in a manual truck they drove differently. Shift points were different, acceleration was different, coasting was initiated at different times, etc...
It seems I need to figure out what I am doing with my turbo, log some data and possibly relearn how to drive my truck all over again on the 1023 tunes.
Now I kind of feel like a jackass for promoting GH tunes for the past couple years. I guess for the uniformed PSD owner they are as good as any other.
I want to log several different vendors at partial and full throttle towing and not to try and see a little more of the picture. I am not sure a WOT run is the snapshot I should be looking at...
Brought the camper home Saturday. Drove easy only went about 10 miles. Did a little logging. keep in mind boost readings are hitting the limit of my regulator
Accelerating 1st 2nd 3rd 4th. Boost ebp fairly 1:1 I think I was hitting the regulator here. seems to max out at 20 or 21 when boost comes up slowly. will max around 23 24 if it comes up quickly.
Uphill acceleration in OD FIPW a little high I think. MORE BOOST THAN EBP
....................snip..............
Edit
Sous I agree and am surprised of some of my results. I spoke with Gearhead when I got these tunes about the differences between tunes for standard injectors and my splits with larger nozzles. Part of the difference is less FIPW in my tunes.
