OIL FILTER
Old Apr 10, 2018 | 09:38 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question OIL FILTER
IIRC there are a larger oil filter for our PSD, but I dont remember the part number, does anyone has it and do you recommend it or its a waste of money and whats the best brand?
thanks in advance
Old Apr 10, 2018 | 10:38 AM
knottyrope's Avatar
knottyrope
FL-1995 is what I use
This is about double in size of a FL-1995
ELF7405 | Donaldson Oil Filter
Old Apr 10, 2018 | 10:40 AM
oldbird1965's Avatar
oldbird1965
The big Donaldson oil filter. I can get under and look if someone doesn't have a part number handy. Knotty beat me, lol
Old Apr 10, 2018 | 10:59 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
GRACIAS AMIGOS. And do you think is it worth to use it? Any cross reference with other brands?
Old Apr 10, 2018 | 01:22 PM
oldbird1965
I use it Jose + the FS2500 oil bypass system. The way I beat on my truck I think its important to keep the oil as clean as I can.
Old Apr 10, 2018 | 08:14 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
How much more oil does that filter add over the stock Motorkraft unit?
Old Apr 10, 2018 | 10:37 PM
oldbird1965
Probably one quart compared to three quarts.
Old Apr 11, 2018 | 08:38 AM
knottyrope's Avatar
knottyrope
My take
The bigger filter isn't going to do miracles and an extra quart isn't much of an increase compared to the 16 we already use in it
You still have to change the oil when the oil is worn out and since its bigger you can go longer between filter changes but that leaves more oil not changed
With an oil bypass and proven oil that holds up better to shearing with lab testing, you can extend you oil change intervals
Old Apr 11, 2018 | 10:50 AM
Hit Man X's Avatar
Hit Man X
I thought we spec'd 14 quarts with stock filter?
Old Apr 11, 2018 | 10:58 AM
oldbird1965
Last time I changed oil it was 16 1/2 quarts with the big filter and FS2500.
Old Apr 11, 2018 | 12:36 PM
dclack's Avatar
dclack
Here's the DBL7405 (which replaced the ELF7405) for a much better price, and you can buy one at a time... https://www.ryderfleetproducts.com/d...-p-w26-dbl7405
Old Apr 11, 2018 | 12:47 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Thanks for all the coments and input.
Corner Gas
Sep 25, 2010 09:53 PM
JimBrazil
Apr 8, 2007 03:15 PM
eco
Oil & Lubrication
Mar 22, 2007 04:08 PM
tim brown
Aug 8, 2004 10:00 PM
duckcrazy
Jan 6, 2002 12:13 PM
