Ok, first attempt at logging with Forscan. Showing a 2nd through 5th gear run. Don't think I was quite at wide open throttle for parts of the run. Other than low boost due to leaky up pipes, any thing obviously amiss?
I can see the boost leak, and that EBP with Kilo Pascals needed conversion to PSI on my calculator. I don't understand the ICP pulse, that's weird - but the values look right. Is there another ICP option in the list?
