Help please
04-09-2018, 05:08 PM
on
Help please
I have a 97 f350 7.3, dome light and odometer quit at the same time, truck is shifting hard and I have to feather the accelerator to get it to shift. Was told possibly the solenoid pack in the transmission, or the brain box. Thanks in advance.
04-09-2018, 05:30 PM
We will try to get this moved to the OBS section so that you can receive more informed/relevant assistance. Welcome to FTE. You found the best forum on the net.
https://www.ford-trucks.com/forums/forum170/
There are awesome guys and gals there as well.
04-09-2018, 05:34 PM
Your in the wrong forum but how does the trans fluid look, how many miles and have you serviced the trans lately. How many miles on the rig?
Dome light and Odometer are unrelated to each other and everything as a whole.
Denny
04-09-2018, 08:50 PM
Moved to the OBS forum.
Stewart
04-09-2018, 08:58 PM
on
Quote:
Originally Posted by
DieselDenny
Denny
319,000 miles, fluid looks good and doesn't smell burnt. Transmission was serviced about a year ago.
04-09-2018, 10:16 PM
You say the odometer quit, meaning there are no digits displayed, or the mileage numbers do not increase? If no digits are displayed, check fuse #18 in the in cabin fuse panel.
04-10-2018, 04:14 AM
on
farmert
yes, the odometer quit, no mileage showing and the speedometer quit as well. I checked all the fuses when it first happened, none of them were bad.
04-10-2018, 12:20 PM
Iamiis
Did you checked the fuses with a volmeter or just with your eyes?
04-11-2018, 03:46 AM
on
RÖENTGEEP
just by sight
04-11-2018, 12:53 PM
Iamiis
just by sight
You should use a voltmeter.
04-11-2018, 10:57 PM
No, you should use an OHMmeter. Or continuity tester.
04-12-2018, 09:41 AM
madpogue
Good call mad, my bad. I should put only meter or tester with ohm meter, continuity and also has volmeter.
04-12-2018, 10:59 AM
madpogue
Play nice. =)
English isn't his first language ya know.
As well, shop talk volt meter = voltohmeter.
But whatever. =)
04-12-2018, 11:08 AM
Talyn
Play nice. =)
But whatever. =)
To have a friend like that or be a friend like that = priceless
PS I should put the first time: A multimeter or a multitester, also known as a VOM (volt-ohm-milliammeter)
04-12-2018, 12:18 PM
RÖENTGEEP
Don't worry...English is my first language and I still call it a voltmeter at times. We all know what you're talking about so you're good.
Most people call wheels, rims, which is incorrect too, but most people understand and accept it.
Stewart
