Buying a TT and TV, I'm new and have gone nuts with learning!
You are correct. That is exactly why the OP should zero in on the travel trailer they want first. Once they pick their TT, they will know what they need to safely and successfully pull that TT making it easier to pick the right truck for the job and ... they will not be limited by a premature, undersizing miscalculation/decision.
Actually more than what I want but the little lady saw it and at least its something to compare with.
https://www.granddesignrv.com/showro...orplans/2950rl
Thanks
Received 6,629 Likes
on
GVWR of 8995 would yield a pin weight of around 1,800 lbs, fully loaded. That's a fairly light fifth wheel. Compare that pin weight to the cargo capacity of an F-250. Sure, it will pull it, but you'll have to be careful to not load much in the truck. A better alternative would be to get an F-350 which will give you a much better buffer on cargo capacity. My well options F-350 6.7L CCLB 4x4 Lariat Ultimate has a cargo capacity of just over 3,100 lbs.
on
Not to hijack this thread but, will a F250 4x4 CC SB, Gas or Diesel be able to pull/handle this. Im trying to get a handle on whats possible and whats not as far as towing and what to look for and this would be at our upper limits.
Thanks
Thanks
That's almost exactly the specs on my 2014 Outback 295RE we pull with a 2011 F-250 Lariat FX4 CCSB 6.2L.
We're mostly pulling Texas flatlands/hills with the Hill country stuff thrown in. No issues at all.
I use a Blue Ox WDH (came with TT) and swapped out the stock hitch for a Curt XD+ with a 2550 TW rating n it. My TW is a around 1300-1400 loaded up for camping.
Griz
Griz
Thanks
Thanks
Either a gas or diesel F250 will pull this. However, if it were me, I'd step up to a F350 for the extra GVWR (on paper). BTW - the older F250 and F350's are essentially the same truck except for the larger 4" rear blocks in the F350 and the higher GVWR. You'll also want to look at things like tow package option, and the camper package option too.
Good Luck and let us know where you end up.
The TT you're looing at is rated at 9,000 lbs. by the manufacturer. Many do not include options in that number. If it were me, I'd figure another 2,500-3,000 lbs. for people, fuel, weight distribution hitch, camping supplies, water if you drive with full tanks, tools and possible TT options if not included in the initial 9,000 lbs. weight rating. Taking the accepted 10-15% of TT weight as recommended tongue weight, you'll likely come in at somewhere between 1,200 to 1,500 lbs. on the tongue.
Any super duty of any configuration will pull this camper fine. In fact, a properly equipped F150 can do it. Regardless of the truck, watch how much weight goes into the bed. And if the bed is empty and you're getting a superduty anyway, I'd take a look at fivers. They cost a little more, but are much easier and faster to hitch/unhitch. TT's tow well when properly hitched but will never be more stable than a fiver.
on
Sometimes the factory weight doesn't include options. So what you get is the weight for a very base model. It varies from manufacturer to manufacturer. Buyer beware. Trust, but verify. Etc, etc...
#29
If you look a little longer, you can get a TT with bunks in the back, a slide out, and an outdoor grill set in the 25-26' range. That's a ton shorter than 34'. 25'+ isn't fun for me.
My 17 250XL was rebated down to $38,000. Only a little over your budget, new. I'd suggest a 6.2L F250, WD hitch, and a rear sway bar for an under 9000# TT.
191124x7
Fifth Wheel & Gooseneck RV Towing
79
08-13-2021 11:10 AM
