Emergency Switch -numberdummy C6TZ-13A350-A
While pulling out my emergency warning switch from the box of parts i got with the truck, I noticed one of the prongs was severely bent. When i tried to straighten it, it broke.
I dont think this can be repaired, right?
I will start to look for another.
Numberdummy, i was reading a thread earlier where you explained exactly which way this switch and the bracket that holds it in is to be installed. It was interesting to read, but i did not save it. Any chance you can pull it up again. It was quite specific in which way it faced.
C6TZ-13A350-A ..
Thanks
C6TZ-13A350-A ..
Thanks
I don't think this can be repaired, right? I will start to look for another.
C6TZ-13A350-A
C6TZ-13A350-A
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 4 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 18 = 800-543-4959.
Upper pic (click on it twice to enlarge it. then use the cursor to move it):
Thanks for the pictures. I have the cd and was able to pull that up. What i really wanted was this. I finally found it. Thanks again
From a previous numberdummy post:
The mounting bracket (C3TZ-15B597-A [same 1963/65]) retains both the switch and the flasher to the dash. Without it, these parts would be as worthless as teats on a mule, because there would be no way to install them.
The whole enchilada is shown here in an exploded view: 1964/72 Ford Truck Parts Catalog / Illustration Section 145.2, Page 1.
You will need to view this pic. Ask FTE member Old Harley to scan and post it, as he has this catalog on a CD. You can buy your own CD catalog from hipoparts.com for $21.95, a roaring bargain.
You will see that you have to drill a hole in the dash to the left of the switch to install the lamp. The switches bezel has threads on its backside, threads off/on the bracket.
Remove the ****, unscrew the bezel. The bracket butts up to the dash, the open section points towards the floor. Once the bracket is butted up, screw the bezel back on, then reinstall the ****.
The 4 way switch **** is the same as the wiper switch **** (C1TF-17513-A). The **** has a #8 -30 headless set screw that retains it in place on the shaft.
Hold the lamp socket with one hand, push the spring loaded bezel forward with the other, then while holding it, twist the bezel off by a 1/4 turn from the socket.
The bezel fits on the outside of the dash, the spring loaded socket w/wiring behind the dash.
See that white piece of tape looped over the wire? That has a Ford ID number printed on it. The first 3 digits of its prefix should begin with C5T if this setup is for a 1965.
Ben, you do have that part number correct for the switch used After the 858,001 serial. (May of 1966)
I just chimed in with a slight correction on which bracket part number was used After the 858,001 serial. You can see in my prior picture how the emergency flasher sits in the bracket and can butt up against the switch. The bracket in the ND prior post that you referenced is the correct number Before the 858,001 serial.
Chad
Chad
fireball14513
15
04-21-2016 03:52 PM
mzerega
02-15-2014 02:19 PM
1965F100(3onthetree)
05-06-2012 06:03 PM
pancake
1997 - 2003 F150
01-10-2010 07:30 PM
49f1fan
07-01-2009 02:15 PM
