New 59’ F350 Owner.
New 59’ F350 Owner.
Thought I’d introduce myself to the forum. I bought the truck a few months ago literally the night before I deployed. I saw her and knew I had to have it haha. Ended up driving 16 hours straight through the night and rain. I’ve been lurking on the forums since just trying to soak up information and learn from all you guys. I’m mostly a Mopar man myself but have a thing for 56-62 Fords. Dont have too big of plans for her yet. Maybe change the gearing out and cruise, restore the bed and make a stake truck, or even hunt down a 9’ Express bed.
Again I just wanted to introduce myself and say thanks for all the info I’ve learned so far.
Nice truck!! How far do you plan to go with it? I'm kinda a purist as far as looks go, but I've made changes to mine. Most brake parts are available, except rear drums. I kept my 6 lug rear and added an auxiliary overdrive to get better cruising. Are you going to do any hauling? Or just not sure right now?
Don't have too big of plans for her yet. Maybe change the gearing out and cruise, restore the bed and make a stake truck, or even hunt down a 9’ Express bed.
There are two F350 9' Express beds, one is a Flareside (1953/72 F350), the other is a Styleside (1957/66 F350), but...
Ford did not offer an F350 DRW (Dual Rear Wheel) pickup until 1980. Fiberglass fenders bolted to the Styleside's quarter panels (bed sides).
All 1953/79 F350's with DRW's were sold as a Cab & Chassis, or with factory installed flat and stake beds.
on
1 Post
Actually the front drums are available. They were also used on dodge's into the late 60's. The rear drums are unatanium. If your not hauling anything and they're adjusted right, all you need is a good foot pressure and that truck stops fine. I'm hauling about 700-900lbs all the time on mine, and have no issues stopping. Wheel cylinders and rubber lines are available too.
I've done mostly mechanical work. My truck came with a 5.83 diff in it. I was able to obtain a 5.14 ratio. Being a Rockwell axle, you can't just go buy a ring and pinion like the later trucks with Dana rears. I didn't change the rear cause I like the originality of my truck. Plus, it had brand new Yokahama radials on it all the way around. So why go to an 8 lug rear and not be able to use the tires? I picked up another rear from a guy who had done just that. His axle had new brake shoes and freshly cut drums, so I used them and sold my old drums to another member here who need a set. They were actually still good too. I also replaced the rubber lines to all the brakes. Autozone has them. Shop around for better price though, I didn't buy them there. I added an auxiliary transmission with 15% overdrive, so I can run on the highway a little better screaming just a little less. 3,000 at 65mph. Clutch slave available at Advance auto for like $32. Replaced mine. New heater core. There's another post on here about that. O'Reilly's auto, $26.99 Finally, I'm in the process of replacing the engine. It's tired. I went to 2 shows in 2 weeks time. 350 miles total round trip for both, 3 quarts of oil.
I haven't done a thing to the body, oh yeah, I waxed it. I bought it in 2009 and it's exactly the same. I did bolt a vise to the bed though. Great workbench and storage unit. It takes me 1/2hr to clean it off every time I want to drive it.
I’d like to keep it with a least period correct look. No hot rodding or crazy paint jobs. I hope to fix her up and bring her to a point where I can reliably drive so I can haul around my other projects. I’ll have to research changing out the drums for discs in front. Add a brake controller. Dual master cylinder. Not much more then that tho; I firmly believe in keeping these old girls on the road.
