Battery life in the 6.7 ? - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 02-12-2019, 09:33 AM
Irelands child's Avatar
Irelands child
Irelands child is offline
Irelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to behold
Originally Posted by The Bone View Post
Swollen batteries may be a condition of overcharging. You need to have the alternator checked to make sure it isn't overcharging them.I have had good luck with Motorcraft batteries as a whole. I did replace one when my truck was a year old because the hold down was corroded. the battery didn't look like it was leaking but the corrosion came from somewhere
Absolutely correct!
  #77
Old 02-12-2019, 05:05 PM
dirthawg's Avatar
dirthawg
dirthawg is offline
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
Cold weather will kill any battery.
Actually heat is the killer. The cold brings out the batteries weekend state.
  #78
Old 02-13-2019, 02:13 AM
2009kr
2009kr is online now
2009kr is gaining momentum as a positive member of FTE.
Originally Posted by Just Strokin View Post
Ford uses the Battery/Gylcol Antifreeze tester as a more accurate reading of the battery specific gravity. More accurate than the ***** floating.
Can also be used to test the antifreeze.
Can buy cheaper model for $15.00 or less.
https://www.ebay.com/sch/i.html?_fro...reeze&_sacat=0
I use the same type of device to rest the salinity in my aquariums. I can see this being very useful for antifreeze. Personally, I wouldn't want such a messy device (gotta clean the glass, plastic cover, eye droper, and hinge area after each test) with strong acid. I also wouldn't use a device that gets my hands and the device WAY too close to my eyes when working with strong acid. It'll measure well, but is too dangerous for me.
  #79
Old 02-13-2019, 04:15 PM
Mayne Man's Avatar
Mayne Man
Mayne Man is offline
Mayne Man is starting off with a positive reputation.
Originally Posted by pacnorwest View Post
Have you replaced the batteries in your 6.7 yet?
Did you wait until the old ones died?
Reason I ask is that my truck & batteries were 3.5 years old and I got uncomfortable about getting stranded with dead batteries.
(I happened to get stranded in my Jeep with it's factory battery - approximately 4 years old on Easter day. I didn't like that a bit.)
So I replaced both batteries in my 2015 Super Duty (took delivery in Aug 2014).
Just wondering what the factory battery life expectancy might be?
My truck is 2011 purchased new. Batteries are still going strong withought a problem. 8 1/2 years. I am trying for 10.
  #80
Old 02-13-2019, 06:18 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Originally Posted by dirthawg View Post
Actually heat is the killer. The cold brings out the batteries weakened state.
"Batteries die in July, they just don't fall over till December."
  #81
Old 02-13-2019, 07:09 PM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I agree. My second set, Diehard Platinum's, began to get weak in March '17. I put a charger to them once or twice but it became spring over a weekend and didn't have an issue all summer until the first cool day in mid November '17. Batteries were just barely able to turn over the engine at that point.
  #82
Old 02-14-2019, 07:28 AM
troverman's Avatar
troverman
troverman is offline
troverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud of
A family member's 2011 F-550, purchased new, with the 6.7L is also on the original batteries.
TooManyToys.
03-07-2019 03:39 PM
nycsteve
6.4L Power Stroke Diesel
10-19-2009 08:48 PM
Country Sweetie
The Next Generation
26
12-02-2006 07:58 PM
Skeetshooter
20
12-15-2003 09:22 PM
Buttroast98
Ranger & B-Series
09-16-2002 06:16 PM
Quick Reply: Battery life in the 6.7 ?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
