Battery life in the 6.7 ? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 12-24-2018, 07:30 AM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
Chuck-B is gaining momentum as a positive member of FTE.Chuck-B is gaining momentum as a positive member of FTE.
My 2013 still have the original batteries in it. I know my time is limited.
  #62
Old 12-24-2018, 10:46 AM
Irelands child's Avatar
Irelands child
Irelands child is offline
Irelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to behold
Originally Posted by HRTKD View Post
8 years is pretty good! You must be doing something right.
I've been waiting for at least 3 years for that dreaded solenoid click of battery death after not so good luck with Motorcraft battery deaths in past Ford F series trucks and various cars. $2-300 for a pair of new ones will not help the budget but neither does a trip to the grocery store (I am looking as these just aren't going to last much longer)
  #63
Old 12-25-2018, 10:55 AM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
My 2015 Motorcraft batterys still starting great but gassing/leaking and making a mess. I've never had a Motorcraft battery fail on me but everyone has started gassing/leaking by year four. Just changed them out for 850 Interstates for 95 bucks at Costco.
  #64
Old 02-07-2019, 02:03 PM
Irelands child
Well that dreaded click of death happened yesterday. $300 bucks later two new Motorcraft BXT-65 batteries are residing under the hood of my truck. I doubt that these will last 9 years (106 months) but who knows
  #65
Old 02-07-2019, 02:22 PM
HRTKD's Avatar
HRTKD
HRTKD is online now
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
Don't wait for the click! Buy a battery hygrometer and periodically test each cell in the battery. I used one on my RV trailer batteries to confirm that one cell was bad.
  #66
Old 02-08-2019, 06:06 AM
Irelands child
Camper batteries - another 2-300 bucks each on the 2019 springtime horizon. Then there is that $$$ Odyssey in my '31 street rod. These are sealed units so a hydrometer wont work though a load or multimeter test will
  #67
Old 02-09-2019, 10:19 AM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
Everytime I go to this thread I tremble - it's tick tick tick, it's sorta like the Langoliers movie, I can feel them coming - Dave's 2011 click of death is creeping closer to 2013
  #68
Old 02-09-2019, 10:50 AM
lynnmor
lynnmor is online now
lynnmor has a good reputation on FTE.lynnmor has a good reputation on FTE.
I noticed some corrosion on one battery connection which is one sign of impending battery death. Although I fully charged them a few days ago, the hydrometer and voltmeter said that the grim reaper is coming soon. Eight years and two months and I might have to replace them already.
  #69
Old 02-09-2019, 10:53 AM
jav_eee
jav_eee is online now
jav_eee is gaining momentum as a positive member of FTE.jav_eee is gaining momentum as a positive member of FTE.
"Already" hahaha I wish mine had lasted that long. I got a hair under 4 years out of mine.
  #70
Old 02-11-2019, 01:19 PM
The Bone's Avatar
The Bone
The Bone is offline
The Bone has a good reputation on FTE.The Bone has a good reputation on FTE.
Every time I have the oil changed they do a battery load test on my batteries. 4 years and all is well. No leaking.
  #71
Old 02-11-2019, 01:49 PM
Just Strokin
Just Strokin is online now
Just Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud of
Ford uses the Battery/Gylcol Antifreeze tester as a more accurate reading of the battery specific gravity. More accurate than the ***** floating.
Can also be used to test the antifreeze.
Can buy cheaper model for $15.00 or less.
https://www.ebay.com/sch/i.html?_fro...reeze&_sacat=0
  #72
Old 02-11-2019, 02:16 PM
Gearitis
Gearitis is offline
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
I went out and did not even get a click Saturday morning. And I had just driven it the day before and did not notice any issues. Batteries, when removed were swelled and also had some leaking. Original Motorcrafts, would have been 4 years in May. And I had just had PM done less than 90 days ago.
  #73
Old 02-11-2019, 03:37 PM
cappa
cappa is offline
cappa is gaining momentum as a positive member of FTE.
Just replaced both on my 2015 after 3.5 years and 85000km. It was -35c that morning and it just clicked once and didn't even turn over. Truck was plugged in for 12hrs. Replaced with two new 850cca's and it started right up. The Crappy motorcraft's had been leaking since the first year of service. Terminals had some corrosion on them when I swapped out. I had noticed prior to the failure that it sounded like it was cranking over slightly slower but it was cold out at the time and the truck sat for 3 or 4 days at a time this winter.
  #74
Old 02-12-2019, 08:51 AM
The Bone's Avatar
The Bone
The Bone is offline
Ford would have replaced your batteries under the 3/36 warranty. If your batteries are leaking they are JUNK. it's that simple and Ford will replace them. Cold weather will kill any battery. I remember when I was a kid in Iowa it would be so cold that the motor woildn't turn over ether. Higher CCA will overcome the cold but after a few years of this the cold will kill them also.
  #75
Old 02-12-2019, 08:57 AM
The Bone's Avatar
The Bone
The Bone is offline
Swollen batteries may be a condition of overcharging. You need to have the alternator checked to make sure it isn't overcharging them.I have had good luck with Motorcraft batteries as a whole. I did replace one when my truck was a year old because the hold down was corroded. the battery didn't look like it was leaking but the corrosion came from somewhere
Quick Reply: Battery life in the 6.7 ?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
