Battery life in the 6.7 ?
#46
#47
#48
My factory Motorcraft batteries made it 6 years, and roughly 100k miles. The majority of that time, was spent in the blazing heat in Phoenix, now the truck lives in the mountains of Northern AZ. It'll be interesting seeing the difference in life from heat vs. cold. Replaced with Motorcrafts.
#49
Sams club batteries are made by East Penn Battery co. which is the same company that makes DEKA batteries which are OEM for Caterpillar.
I talked to a driver at east Penn delivering to Sams and asked him if the different names on these batteries are as good as DEKA and his reply was all EAST Penn batteries are made with the same quality regardless of name.
Yes the AGM are better cost more as most things of quality do, will take more abuse than wet cell technology.
My 2011 F-350 6.7 PS has the OEM batteries still...
Tip: I recommend putting those treated felt washers over each battery post when doing a replacement of batteries. They can be purchased at WalMart for .99 cents for a pair. Use Arm & Hammer Baking Soda mixed with warm water to clean the corrosion off cables and battery posts.
This solution does a good job of cleaning all acid off top of batteries.
#50
#51
I am by no means any kind of an expert on this but this thread got me drilling into batteries. From what I was able to find and thought I would share is that it appears that there are 2 "types" of batteries, Deep Cycle and Starter / Starting. From what I read, deep cycle batteries hold a charge / produce power for a longer period of time than starter batteries but are not typically good at the burst of power needed to start a vehicle. Because they hold power longer they put a greater load on the voltage regulator and alternators to recharge them and can lead to voltage regulator and alternator "problems". I was very disappointed to read that most AGM batteries are typically deep cycle batteries. I think Optima makes an AGM starter (or starting) battery. The Deka / East Penn Manufacturing site says the Intimidator is a "deep cycle starting" battery, so both?. Am I reading way too much into this and the charging system of the 11 - 16 6.7 won't know the difference? Or should we stick with a starter / starting battery? Oh and I know, go to your local Ford dealer and just put the Motorcraft battery in the truck and be done with it. For me, I'm always looking for something "better" or at least in my mind "better".
#53
Received 6,686 Likes
on
Chuck-B, I had an Odyssey PC1700 AGM battery in my half ton. That truck started like a raped ape. It was a very good battery. Expensive, slightly lighter than OEM and pretty much an exact fit. It died, but it happened slowly. It gave me plenty of warning that it was on it's way out. I was just shy of the warranty expiring and Odyssey replaced it, no questions asked, no proration. Will I replace the OEM batteries with Odyssey when the time comes? Probably.
#54
#55
#56
^^And most of the Ford diesels are now coming standard (by way of packages) with dual alternators at 332 or 377A total. There shouldn't be a charging concern. Plus these trucks have much more sophisticated "State of Charge" (SOC) monitors right on the battery post connections which can more accurately provide info to the electrical system.
#57
#58
Guess I had best think about untying the purse strings and look for a couple new batteries as my Job 1, May 2010 build truck's are March 2010 manufacture and at 116,000+ miles. I hate to do that since the truck is still starting well but the odds are going against me at 105 monyhs. Being caught in West Overshoe on a Saturday evening with our 5er in tow is not something to look forward to experiencing.
#59
on
#60
My 2012 that was Born on 9/27/12 dual batteries lasted till October 2017. I started to get a clicking when starting and check engine light that showed low voltage to the PCM or some module. Was still able to start and drive for 3 more days till the battery completely fell flat. Went to the ford dealer and replaced both batteries, fixed everything.
