04 PSD 6.0 Random white smoke and power loss - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-02-2018, 06:57 PM
jovol
jovol is offline
jovol is starting off with a positive reputation.
I'm pretty certain this subject has been beat to death in terms of the possible culprits of this symptom, but I'm working with a mechanic tomorrow night and I want to be as prepared as possible to diagnose what's actually wrong. With that in mind...
I have a 205k miles 04 F350. I bought it used a few thousand miles ago. It was studded about 3 years ago at 180k miles, got a new oil cooler, coolant filter; it's been deleted (via welding it shut, I believe). Turbo was replaced at 150k miles. The problem has happened twice now: I'm cruising on the highway in 5th, ~65 mph, and I lose power and see white smoke coming out the exhaust. I come off the throttle for a few seconds, and it's all back to normal. This happened last Saturday, no trailer or heavy load, 70F, and two saturdays ago I was pulling an empty trailer.
I think the coolant level has gone down, but not conclusive (I just topped it off today and will monitor it closely now). I'm nervous it's a head gasket issue, since the studding and all work was done by the previous owner, not a proper shop. It has an Edge turner so I can read the temps. ECT is generally 190F, getting to ~205F up long grades. EOT stays close to ECT, except when cruising back down the grades after a climb (it takes ~5 minutes for the EOT to get back to ECT +/- 5F). EGTs seem normal; up steep grades they get to 1200s, normally 500-800.
Any hints where the mechanic and I should check?
Thanks kindly,
john
Old 04-03-2018, 05:07 PM
jovol
jovol is offline
Bumpp. Headed to the mechanic now, will report back if we find anything
Old 04-04-2018, 12:43 AM
jovol
jovol is offline
So he hooked up his computer and we drove around. The FICM voltage was consistently less than 48V, typically 46-47V. We suspect that the voltage is dropping randomly when those power loses have happened. Gonna replace it and hope it's fixed! He definitely doesn't think it's a head gasket issue since there is no coolant being pushed out of the reservoir.
Old 04-04-2018, 06:59 AM
P.Bronner
P.Bronner is offline
P.Bronner has a good reputation on FTE.P.Bronner has a good reputation on FTE.
EGR cooler leaking maybe?
Old 04-04-2018, 06:40 PM
jovol
jovol is offline
Would that happen randomly and inconsistently? The white smoke/power loss has happened to me twice over the course of ~1.5k miles.
Old 01-21-2019, 12:51 PM
jovol
jovol is offline
I hate threads that have no resolution, and I just remembered I never updated this post.
6 months ago my mechanic replaced the IPR valve on a whim, and all the issues were fixed. Hope this helps someone...
jonesey-x
06-03-2015 09:24 PM
cowboykb
17
12-14-2011 11:31 PM
qtrmile
05-19-2007 09:16 PM
qtrmile
05-19-2007 06:20 PM
fishfanatic
10-22-2005 04:25 PM
Quick Reply: 04 PSD 6.0 Random white smoke and power loss
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
