How do these dome lights connect?
I bought this dome light from LMC (that may be the issue ). I can't figure out how to wire it in, is there a special pigtail? I couldn't find one in any of the aftermarket catalogs. It is supposed to be a direct replacement, but I can't find anyplace to attach wires. I have an aftermarket (Painless) wiring harness, so I don't have the original connections. Ideas?
No connections anywhere, what's the deal?
Post number 8 in this thread shows a wire. https://www.ford-trucks.com/forums/1...l#post11411331 Good luck.
Originally you would remove old dome light and put your new one in its place. But you have new wiring harness. Have you stripped the cab of the wire that goes up the drivers side A-pillar beside the windshield and along the side of the roof of the cab around the rear corner to the dome light? Original connection is a rubber block with a hole in it where the screw goes when you screw the dome light in place, the connection is made through the top right screw, the screw is the connection (I know, weird right?) the dome light only goes on one-way as the plastic is formed with an indentation next to that screw hole for the rubber block to fit there.
Man, that is weird. Thanks for your help, that's exactly the info I was looking for. I might try to whip something up myself.
https://www.superbrightleds.com/more...-44mm-car/244/
